Oil cooler o-ring and oil filter housing-to-block gasket replacement, part 1
I want those lights! So tired of dull plastic lenses (even after polishing them)
I will be doing a careful comparison of before and after lighting options with photos and measurements of light beam pattern and distance, eventually. One thing worth considering if your stock lights still have functional beam aiming adjustments (unlike my driver's side), get another set of the high beam bulbs and file off the tabs - and they fit without a problem in the low beam emplacements. So long as you aim them down a bit, you will have *excellent* light and not blind anyone.
Maybe next weekend shall I do the above light work on my car, we shall see... because THIS weekend, by popular request...
Ok-pull it up on ramps(or put it on jackstands if no ramps) and chock the wheels.You NEED to find the source of that leak-I would re-check the turbo supply line ,oil cooler seal,is the oil filter tight enough? Hate to see you put all the time into the interior only to have the engine crap out from no oil......
... I am doing this:
Hunting the remaining source(s) of the prodigious oil leaks from
my car.
Based on this sort of spray pattern which is a new development amongst the oily mess...
... our family friend mechanic and I were able to determine it is something along or on the oil filter housing - the rest of the engine is oily and/or drippy because of air pressure + oil pressure mucking it all up. I don't even want to talk about all the times I thought I had found The Leak, cleaned it up... and found it was just accumulated oil which was dripping, not a source.
So after 22 or 23 minutes of varying RPM driving with BG 109 (per
Lug Nut's post, in
this thread), I drained the oil and let it drip for a while. The old drain plug is on the left with a crush washer reused an unknown number of times (another possible leak point); the brand new magnetic plug is on the right:
For the benefit of others who do this for the first time, a photo of the filter housing pipe coming through the oil cooler. You will need a 27mm deep socket to get that slim nut as well as a 1/2" drive swivel adaptor. You will then need a 3/8" internal pipe wrench, to use its elliptical pattern movement within the pipe to loosen it (rather than potentially damaging threads by gripping the pipe with pliers).
I don't want to talk about how many times I went to the hardware store today, to get other adapters or tools unexpectedly.
Anyways, the aforementioned photo:
... now removed and next to the internal pipe wrench (for your referential edification), it is very clean because constant oil immersion, and appears to have been tightened enough to avoid leaks itself:
So after a lot of fighting to get this far, I had the oil cooler off and could pull the old gasket. And it was the old gasket - I believe it could very well be the original one, because though it wasn't cracked, the rubber material was harder than plastic, extremely compressed, and was in the right physical location for a lot of the oil spray originating in the engine.
Right side is the old gasket, sorry for any lack of clarity:
Then... I got to start fighting with the goddamned allan bolts holding the oil filter housing to the block. The top one was easiest for me, because I removed the vacuum pump and several wires, and then I loosened the plastic tube going to the CCV puck.
Wat:
I have driven the car 350 or so miles since rebuilding the heater core + soundproofing the interior, and
those miles were with a goddamned acorn in the lines.
My
initial reaction was unbecoming someone who has trained to be a pastor.
My secondary reaction was "wow, my car is even more stupidly reliable than I thought - is this some kind of elite level of bio-diesel?"
Nevertheless, I got the top bolt out tonight, and then just had a hell of a time with the lower two. Partially for a lack of the right swivel for my ratchet, which I went out and got, then came home and called it a night.
The night closes with the oil cooler detached and (as far as I have been able to inspect in a visual or tactile way, free from dents or holes) and 1/3 of the oil filter housing unbolted:
Tomorrow shall see me fight the last two bolts, then scrape the stock gasket off the head and install the embossed metal replacement, then rebuild the hole thing.
... and test drive it, and hope and pray the ecological disaster oil leaks are gone.
Part II of this post to follow tomorrow.
