The driver's door window is having problems. It will go up and down just fine for the top 60% or so of travel. Below that it starts making groaning noises and eventually stops about 75% of the way down. Like it had hit an obstruction of some sort, or thinks that it has bottomed out. On the way up, it makes some noises at first then is fine from about the 60% to the top.
I'd like to fix this, but don't want to order unnecessary parts. And if possible would like to not have to take the door apart more than once.
Can anyone here identify what the likely cause is from these symptoms? New regulator? Window channel gummed up or rusted? Any thoughts?
