Applications
Mobil Clean 7500 5W-20 is recommended for vehicles which call for an API certified (Starburst) , 5W-20 viscosity grade engine oil such as 2001 and newer model year Ford automobiles, 1998 and newer model year Honda Accords, 1996 and newer Honda Civics, and certain 2005 Chrysler vehicles. This unique viscosity grade should be used only in automobiles that require a 5W-20 lubricant and it is not recommended for use in other vehicles. Mobil Clean 7500 5W-30 and Mobil Clean 7500 10W-30 are recommended for gasoline fueled automobiles and light duty trucks requiring an API SM, SL or SJ product or API CF or CD. They meet ILSAC GF-4 (Starburst Certification Symbol). Before using Mobil Clean 7500 performance motor oil, consult the owner's manual of the vehicle for the manufacturer's recommended viscosity grade and API Service Classification. Mobil Clean 7500 should not be used to extend drain intervals under certain consumer or commercial severe service applications involving racing, frequent towing or hauling, extremely dusty or dirty conditions, or excessive idling. If your vehicle is covered by a warranty or is equipped with an oil life sensor, follow recommended oil change intervals. Proper maintenance practices, including frequently checking the oil level to ensure that the appropriate oil level is maintained, are required to ensure effective performance.
