Injector priming brm
Fish
Upstate New York
06 brm
Hey guys, I have a 06 brm and I just did a stage 3 cam as well as injectors (pd 150 with 130% fraid nozzles). The car currently has a crank no start, I was wondering if anyone had any tips as to how to prime the injectors. I'm scared to mess with it from the knowledge I've gathered online so far. Any input on how PD injectors work/prime would be very appreciated!
Thanks,
Kyle
JETaah
Vendor , w/Business number
mi 48836
Flip the ignition key a couple dozen times. Each time, listen for the lift pump in the fuel tank to cycle about 2 seconds to bleed the fuel rail. Pull the glow plugs out and, with a freshly charged battery, crank the engine (in ten second intervals) until you see plumes of fuel mist coming out of all 4 of the glow plug holes. Stick the glow plugs back in and it should start right up.
