Keenan
I have an extra Bosch OEM Fuel Injector Pump pulled from my '96 B4 Passat, which I had to swap the engine out of. The pump had 150,000 miles on it and then was rebuilt, which was 10,000 miles ago. It is in perfect condition. Then, my engine threw a rod and had to be replaced. I also have 4 extra injectors to sell as well. They are also the stock OEM injectors.
The IP work on 1Z/AHU engines, which means '95 to '97 Passat TDI, and '96-'99 Jetta TDI. The IP was rebuilt at West Coast Diesel Service in Salinas, California, which is an authorized fuel injection servicer and they calibrated the pump. The pump was last run successfully about 5 months ago before the engine threw a rod.
I am asking for $450 plus shipping, OBO, which is half or less of what you would pay for a freshly rebuilt pump, not including a core which usually costs an extra $300 to $600 if you don't have one.
The injectors will fit all ALH, AHU, and 1Z TDI's from 1995-2004 with manual transmission. They are OEM stock injectors in great shape, with 160,000 miles on them. The Passat ran smooth and was getting 45 mpg before I had to overhaul the engine for the thrown rod. Since the new engine came with IP and injectors, I don't need the extra parts from my old engine. You can either use these to replace bad injectors, or use them for the core with you new order for new injectors (to save up to $600 on the core charge if you don't have old injectors to swap). I am asking $150 for the injectors plus shipping, OBO.
I guess this is a semi-auction, since I will be accepting the best offers, which could be higher or lower than my asking price.
Additional items for sale from same engine:
Turbo assembly with manifold - $350 OBO
Cylinder Head - $350
Accessory Bracket - $40
Hard Fuel Lines - $20
Power Steering Pump - $30
Accessory Belt Tensioner - $30
Oil Filter Housing with Oil Cooler - $50
Intercooler - $40
Vacuum Pump - $40
Fuel Filter Bracket - $10
AC lines - $30
L Shaped Rubber Boost Hose to Intake Manifold - $30
Intake Manifold - $50
Intake Pipe from Intercooler to Intake Manifold - $30
Valve Cover - $30
Oil Pan - $50
EGR Cooler - $20
EGR Cooler Pipes - $10
Intercooler - $40
Vacuum Pump - $40
AC lines - $30
Valve Cover - $30
Oil Pan - $50
EGR Cooler - $20
