Bakeme521
Ok so tonight I finally had time to change the TB so I got after it. The job wasn't too bad, used the DIY in the FAQ section and it helped a bunch. I put everything to TDC and locked it in place except the fuel pump but I was very careful to make sure it did not move. My fuel line pinchers kept popping off so I got a lot of air in the lines. I looked at the procedure and made sure the fuel filter was full and loosened each injector line on til it sprayed but still no luck. Is it possible that if the fuel pump timing is one notch off it won't fire at all? Or am I missing something completely? All my marks lined up with the new TB on, turned over by hand nothing hit anything, can't figure out why it won't start. Does anyone else know where I should look next or maybe is it still air in the lines?
