milktree
- Joined
- Apr 8, 2011
- Location
- Eastern Massachusetts
- TDI
- 2015 Golf Sportwagen, 2004 Jetta Wagon (sold!)
When I look on the 'net, I see a lot of how-tos that say (more or less)
"pull the lower plastic cover thing off, unscrew the two Torx screws, pull the gauges out a bit, unplug the cables, and it comes free."
Now, that seemed way way too easy, so I looked in the Bentley manual, which says (exaggerated for effect) "remove the wheels and lower suspension linkages, remove the transmission and engine, remove the driver's seat, radio, carpet, and climate control stuff. Then remove the entire dash board, then unscrew those two Torx screws mentioned above and wiggle the gauge cluster down and out, &c."
Does the little trim piece between the gauges and steering column really just pop out? How easy is it to break it? Once it's out, does the gauge cluster really come out with only two screws and some wiggling?
