Now I am having this problem. I replaced the engine 2 times. simply bad luck. CJAA in it now. But I am not sure if my particulate filter got plugged form all the problems I had. any thoughts.
Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: Release 21.9.0
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Diagnostic Trouble Code Report
Tuesday,12,October,2021,16:33:17:56036
VIN: License Plate:
Mileage: Repair Order:
Control Module Part Number: 03L 997 030 H HW: 03L 906 022 J
Component and/or Version: R4 2.0l TDI G001AG 9983
Software Coding: 0050078
Work Shop Code: WSC 84224 811 682728
VCID: 336F266752EF8C118C-8066
7 Faults Found:
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 30
Reset counter: 255
Mileage: 433983 km
Time Indication: 0
Date: 2000.00.00
Time: 00:11:30
Freeze Frame:
RPM: 2185 /min
Speed: 111.0 km/h
Load: 60.0 %
(no units): 2388.0
(no units): 1896.0
Lambda: 85.2 %
Lambda: 85.2 %
P0299 - 001 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 30
Reset counter: 255
Mileage: 433983 km
Time Indication: 0
Date: 2000.00.00
Time: 00:11:30
VCDS
Page 2
Freeze Frame:
RPM: 2185 /min
Speed: 111.0 km/h
Load: 60.0 %
(no units): 2388.0
(no units): 1896.0
Lambda: 85.2 %
Lambda: 85.2 %
001025 - EGR System
P0401 - 001 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 55
Reset counter: 255
Mileage: 434026 km
Time Indication: 0
Date: 2000.00.00
Time: 01:34:34
Freeze Frame:
RPM: 2599 /min
Speed: 132.0 km/h
Voltage: 13.15 V
Load: 95.7 %
Load: 100.0 %
Mass Air / Rev.: 460.0 mg/str
Mass Air / Rev.: 445.0 mg/str
008194 - Particulate Trap Bank 1
P2002 - 007 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 434082 km
Time Indication: 0
Date: 2000.00.00
Time: 02:04:19
Freeze Frame:
RPM: 2185 /min
Speed: 111.0 km/h
(no units): 81.6
(no units): 30.6
(no units): 2.25
Pressure: 197 mbar
Pressure: 64 mbar
VCDS
Page 3
009231 - Exhaust Gas Recirculation System
P240F - 000 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 255
Mileage: 434390 km
Time Indication: 0
Date: 2000.00.00
Time: 23:23:22
Freeze Frame:
RPM: 1702 /min
Speed: 86.0 km/h
Load: 65.9 %
Mass Air / Rev.: 0.0 mg/str
Mass Air / Rev.: 20.0 mg/str
Mass Air / Rev.: 260.0 mg/str
Mass Air / Rev.: 320.0 mg/str
001025 - EGR System
P0401 - 002 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 434876 km
Time Indication: 0
Date: 2000.00.00
Time: 06:30:41
Freeze Frame:
RPM: 2507 /min
Speed: 127.0 km/h
Voltage: 13.30 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 730.0 mg/str
Mass Air / Rev.: 725.0 mg/str
009235 - Exhaust Gas Recirculation System
P2413 - 003 - Performance Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 435710 km
Time Indication: 0
VCDS
Page 4
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Torque: 0.0 Nm
Temperature: 91.8°C
Bin. Bits: 00000000
