arizonajetta
hi, new to vw tdi world.. just acquired my 1st tdi..... im a diesel tech at gm... I know most of the goodies, but love the fuel mileage of the vw . its a 2002 vw jetta 1.9 turbo tdi.. 5spd... has a diesel geek clutch and solid flywheel, arp head studs, and kerma stage 2 injectors in it. the original owner blew motoro up when turbo let loose, I now have a rebuild engine with a new or used turbo on it. ... since passing some oil, wanting to know any whay to upgrade the turbocharger with out changing manifolds, or anything weird lake that, all im wanting is boost to come in sooner, a mild raise in boost is ok too. I drive freeway 40 miles a day, so at 70mphish running 2500-2600 rpm, really don't want boost kicking in when hwy driving.... is there any upgraded impeller cartridges I can change to?
also since in az. wanting to add more oil cooling, is any way to add a air in front mounted oil cooler? and ast question, I scored extra parts, can a 2nd stock intercooler be added to the drivers side of lower opening in bumper and piped into the 1st one, to help cool down the air charge some more...? mind you it get to 115 degrees air temp here, road temp more like 125-130.... I want this thing to last..... any thoughts? or suggestions?
