Old July 18th, 2017, 23:41   #6496
vanbcguy
vanbcguy's Avatar
Yes, I used the same gauge on my Rover pump as I used on my old 1.6. The threaded adapter was different though - larger pump plunger = larger adapter.
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old July 19th, 2017, 17:09   #6497
turbodieseldyke
turbodieseldyke's Avatar
TDI(s): 98 jetta
Fuel Economy: 50
Originally Posted by ToddA1 View Post
Why convert from E to M?
I think most of the interest is for EMPs and SHTF. Though there could might maybe possibly be a downside to having the only working car during the apocalypse.
turbodieseldyke is offline   Reply With Quote
Old July 19th, 2017, 18:38   #6498
ToddA1
Fuel Economy: Dismal
Originally Posted by ketchupshirt88 View Post
Besides that, I have no interest in dealing with a tuner after my last experience. Suffice it to say that communication was inadequate, I didn't get what I paid for and I eventually stopped trying to get it.
Sucks, but I have a feeling most tuners are just enthusiasts, who have normal day jobs.
I'm guessing you'll lose the speedo, cruise and some other cluster functions if the ECU isn't seeing the E IP.
I was looking at my Landy pump. I was just thinking find a correct brake fitting and tap the hole to the gauge holder's threads.
I ended up buying a Mantra holder for about $20, which isn't bad considering it shipped from Snap-On. The site I ordered it from, didn't mention Snap-On.
The junk ebay holder was a pain to use.
My AAZ Rabbit will be one of them.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old July 19th, 2017, 23:56   #6499
vanbcguy
vanbcguy's Avatar
Cruise and the tach will be gone without the ECU, the rest of the gauges and the speedo will keep working fine though. The ECU can be left in place without the electronic pump, that'll keep the tach working.
Old July 20th, 2017, 04:35   #6500
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk2's about 48mpg, mk3 ~43mpg thats @(near)80mph(-/+).
haha, yea but its supposed to work. and may be the only thing to work, until,,shortly, there is a fuel shortage. but it ll still be in running order on the bright side. if you can still see the sun that is.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old July 20th, 2017, 10:53   #6501
john.jackson9213
TDI(s): 1996 B4V
Had Matt Phelan take care of a couple of items on the B4V last Monday.
I had been chasing a low boost issue for a while. Matt found it and fixed it in an hour. The inlet hose to the intercooler had a crack in it. He used a radiator hose to fabricate the replacement boost hose. Also solved a small fuel leak to the injectors and reseated all the injectors. (I caused the leak trying to reseat the injecters without the proper tool). Lastly, he cleaned, lubed and adjusted the lock on the rear hatch. Total repair time was two and a half hours.
Now I can reinstall the plastic panel on the tailgate and replace the tailgate struts.
It was good to catch up with Matt again. Nice to have the car running well again.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.21707 seconds with 11 queries
[Output: 76.68 Kb. compressed to 67.15 Kb. by saving 9.52 Kb. (12.42%)]
