2000 Jetta TDI towing capacity
David_Inman
Monroe, Maine
2011 Golf TDI
Anybody have any towing experience that they can share with me? Can my car actually tow more than what VW recommends? I'd like to know how much I could really tow without destroying my car. Thanks!
doc_m
somwhere
None
well I was towing 1800 lbs worth of hard wood flooring plus whatever my trailer weighs.
David_Inman
Monroe, Maine
2011 Golf TDI
Yeah, kind of looking for the straw. I have a 2000 pound tractor plus trailer that I may be too chicken#*&$ to haul, but I would like to get a U-Haul trailer behind it for about 700 miles.
TDI_SC
Columbia, SC
2012 Passat TDI SEL Premium
In all honesty, if you have anything heavy to tow... Why not ask a friend that has a truck, or rent one?
Why put undue stress on your Jetta (or other car)?
I'm a big proponent of "the right tool for the right job". I don't ask my F350 to get 60mpg! :D
JP
INCUBUS
NW Suburbs Chicago
Jetta Wagon, 5spd, 2003, Silver
Towing
Im pretty sure max is 2500 lbs........remember this includes trailer and what ever is on it, people in vehicle+cargo.
DIESELprogrammer
NorEastern, Washington, USA
Golf GLS, 2003, Silver/Gray
Do a little searching on my username and you will find out just about all you need regarding towing with a NA TDI.
The A4 TDI is the right tool for the right towing job. It will tow 1500# as safely as the F350 will tow 10k# and get over twice the fuel mileage doing it.
The A4 1.9TDI 5spd is rated in Europe at 1320# unbraked and 2866# braked. The biggest issue you will have with towing at the higher end in NA is that only a class I hitch is readily available.
Over 11k miles towing this trailer behind my Golf with 1200#-3k# load.
TDI_Dog
Back in little North Beach, Maryland
none - yet. Used to have a '02 MK4 Golf GLS TDI
Towing with 02 Golf
I've towed up to roughly 2800lbs with my 2002 Golf GLS TDI, 5- speed, 137,000 miles on many trips. 5x8 enclosed trailer.
I have a Hidden Hitch bought from e-trailer.com, installed myself (very easy to do). The car has never failed me and always easily maintains highway speeds - 60 - 80mph.
Trailer tows straight - no sway - great stopping, great starting and not bottomed out the rear springs. Usually, there is atleast one other adult in the car with me. I run 480 mile one way trips monthly, sometimes bi-monthly.
JetPuf
Portland/Troutdale Oregon
White '98 Bug, Gray 2010 GL350
I have a Draw-tite off of e-trailer (selected it because it has more mounting points then the hidden hitch (although both will work well). I have personally towed about 2400 pounds of gravel+trailer. Additionally I've hauled boxes and boxes of books for some family members on a 300 mile trip over the river and through the woods totaling about 21-2200 combined trailer/cargo weight plus another 600 in the car. I took it easy and stuck to 60mph even though the posted speed was 65car/55trucks. The lowness of the back end in the car was from the books in the car, the trailer was extremely well balanced and we simply reached our weight limit before we reached the volume capacity.
Do I fit in?
This would be a bit over the towing capacity :cool:
Geordi
Somewhere between Heaven and Hell. But it is reall
14 JSW DSG, 03 Wagon 01M, 400k and IPT performance auto!
Well, let me think. On my 01 Jetta AUTO, with the Draw-Tite from Etrailer (modified install) I have had a 6x10 box trailer with about 1500# of junk in it, plus the weight of Uhauls heavy-arse trailers behind my car, up and down the hills of Kentucky at 80mph without any problems. I have also pulled about 2k worth of concrete tiles on an open utility trailer... And just for giggles, I pulled an 80s Chevy half-ton out of the road (full of tools in the back) and onto the grass. But that was using the loop and a chain, not the hitch, and only at 5mph in first gear.
How did I modify the Draw-Tite install? When installing into the holes I drilled, and into the frame by the tow loop, I used all grade 8 bolts, half-inch thick, and I used 3" wide by 1/8" thick fender washers, on BOTH SIDES of the trunk pan steel, and on the driver's side shoulder steel. This makes that connection a 3" wide tiedown, instead of the 3/4" wide of just the bolt head. The instructions had NOTHING about using washers, OR using rated hardware like grade 8 bolts. Grade 8 is one tough mofo, they don't stretch or shear without extreme forces, probably stronger than the FRAME of the car.
Yea, I'm an engineer, and I over-engineer stuff I build. That's why MY house was still standing with 98% of the roof shingles intact after 3 direct-hit hurricanes in the last 2 years.
BleachedBora
Vendor , w/Business number
Gresham, Oregon
'81 DMC-12, '15 GL350 CDI 275 hp/448 tq - '81 Caddy CJAA, '05 E320 CDI 250hp/450 tq, '23 ID4 AWD Pro S Plus
Nice pics Brian--you should have tried towing the airplane! :)
