Old January 11th, 2018, 10:12   #1
merk
Default Wipers randomly not working
So I have the wiper issue where they work sometimes and not other times.. They are not slow or binding up, just flat out not coming on sometimes. Whats the most likely culprit here?
03 Sedan..
Merk
03 Jetta sedan & 03 Jetta wagon
Panzer skid plates, Bilstein TC's
2016 GMC Canyon 2.8 Duramax
diesel.
merk is offline   Reply With Quote
Old January 11th, 2018, 10:25   #2
BobnOH
Fuel Economy: 50/45/35
If it's not the typical bushing bind, it could be the motor on it's last, but more likely wire/connects/switch.
Old January 11th, 2018, 12:31   #3
jokila
jokila's Avatar
Fuel Economy: 52/45/40
I had that kind of problem for several years. Ended up being the motor for me. Just got tired of not having wipers when I needed it.
On the other hand, RainX is so awesome; you don't even need wipers.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old January 12th, 2018, 08:01   #4
merk
Thanks..The local yard wants $50 So it probably pays to just go new! Heck the salvage motor is as old as mine ... duh..I recently cleaned all the grounds for an alternator issue. they looked good.
Merk
diesel.
Old January 12th, 2018, 09:39   #5
jokila
jokila's Avatar
Be sure to check which motor you have there are two kinds of connectors. My guess is you have the late model like mine did.
https://www.idparts.com/wiper-motor-...ed-p-1159.html
Also, you might need one of these:
https://www.idparts.com/wiper-linkage-a4-p-989.html
I had a heck of a time removing my wipers. Broke one cheap puller from the local parts store. I ended up buying one of these.
Old January 13th, 2018, 08:04   #6
merk
Thanks will check the motor.. ive had my wiper arms off in the last few years so that should not be a problem...
Merk
diesel.
Old January 13th, 2018, 13:45   #7
Vince Waldon
Vince Waldon's Avatar
*Every* time this has happened to me pulling the bottom cover off the steering column and spraying DeOxit into the switch contacts has resolved the issue.
In my experience the switch contacts that carry good-sized loads all by themselves (wipers, turn signals, trunk latch, fuel door) oxidize enough over time that eventually they can't carry the full current load to the downstream motor or solenoid. This shows up as an intermittent fault, depending on what pieces of the two contacts are rubbing together that particular day... and sometimes if you fiddle with the switch it will suddenly work.
Might be worth a try before tearing apart the motor end.
Or, could just be a bad motor.
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old January 13th, 2018, 20:17   #8
Seatman
Seatman's Avatar
Fuel Economy: No idea
For me it was the big double relay, it controls all the wiper functions, often has 377 printed on it.
There's relays inside and the contacts can burn out and fall off. The broken contact actually caused a short one time and I could stop the wipers lol
Seatman is offline   Reply With Quote
Keyless Entry Remote Randomly Stopped Working axelseaa VW B5 Passat TDIs 6 March 16th, 2015 16:40
Wipers not working wphooty VW MKV-A5 Golf/Jettas 8 October 9th, 2012 11:55
wipers still not working jkatdi TDI 101 7 April 26th, 2011 09:02
wipers not working engiman34 TDI 101 1 July 9th, 2010 08:14
Wipers and lights go on randomly SnowCub VW MKIV-A4 TDIs (VE and PD) 1 August 31st, 2006 16:45
Page generated in 0.16664 seconds with 12 queries
[Output: 89.04 Kb. compressed to 76.57 Kb. by saving 12.47 Kb. (14.00%)]
