db123
I'm sorry to those who may be bothered by me starting a new thread about this, but I am wondering if anyone might know if an ALH oil pan would fit a BHW block without any modifications or problems?
I don't think so cause of the b5 subframe. Somebody else may have a better answer.
AVB, AVF, AWX and BGW engine codes used the normal alh oil pump and a windage tray in the passat and audi longitudinal chassis.
Pan is 06B103601AQ
Tray is 06B103623P
All engines not equipped with the balance module had an oil level sensor in the pan. (Balance module got in the way of the sensor on the BHW so it was not used.) You will need to get an oil level sensor to plug the hole or machine a blocking plate.
Just checked and yes, the tray is the same as the ALH part. The pan is the only diffrence. The engine codes I listed with the exception of the AWM are all european engine codes.
It will be pretty easy to find an AWM pan (06B103601P) so I would start there. I can't guarantee the fit but it looks good in the pics. There may be a version without the oil sensor but I have not encountered one in real life. I only have newer AMB 1.8T gas engines kicking around so I cant compare. AMB pans do not have the passat style snub mount holes in them. The audi A4 snub mount bolts to the side. The AWM does have the proper holes, it will just need the turbo drain and oil sensor holes blocked.
