‘01 Forester making WHOMP-WHOMP noise in rear after new brakes
2000alhVW
Silver Spring, MD
2000 Golf
I would start by checking sway bar bushings and end links. They make a lot of noise inside the car even with a little play.
Sent from my STV100-3 using Tapatalk
I think I tried yanking on these, but can't quite remember.
I do remember sending a picture of the rear sway bar to my friend because it's so tiny I almost mistook it for brake lines.
But I did actually confirm the wheel bearing. I removed caliper, bolted wheel back on, and detected radial and axial play, complete with *clunk clunk* noises
Caddy 16v
Hazelton, BC
2000 Jetta, 2000 Golf
Subarus also make a sound like this when the wheels are tightened down too much/ not the correct torque spec.
