Old June 14th, 2018, 20:34   #1
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Default BHW Exhaust Manifold on ALH
Is it possible to use the BHW exhaust manifold with turbo adapter plate on the ALH to upgrade to a GTB2056? I've read some different info on this.
2K jetta gl tdi 5spd 401k, RC5+, 17/22, PP764's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old June 15th, 2018, 09:47   #2
flee
Fuel Economy: 40-ish
If that's the same as the Passat manifold then yes. I have used one with a 1756.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old June 16th, 2018, 18:59   #3
terrydtdi
terrydtdi's Avatar
Awesome, Iíll stick with my plan. Looking at going with a 2056.
Old June 16th, 2018, 21:11   #4
Yourbuddysatin
I think a BHW manifold is the cheap way to fit a GTB type turbo. Could be wrong.
Yourbuddysatin is offline   Reply With Quote
Old June 19th, 2018, 19:12   #5
terrydtdi
terrydtdi's Avatar
It is a more economical way of going about it. I got the adapter plate from Darkside.
Old June 28th, 2018, 10:12   #6
Scott02
TDI(s): Too Many
Fuel Economy: 51/45/41
If looking to go cheap, not a crapload of BHW manifolds floating around... you can also look for AHU/1Z manifolds as the wastegate turbos bolted to the exhaust manifold like the BHW. I used a 1z manifold i found for a nothing for my gt2256v build.
2015 GSW DSG - 27kmi, Kerma engine tune
2011 JSW DSG - 160kmi, Malone DSG tune - Buyback done
03 Jetta Wagon TDI 5MT - 175kmi, 2.5"F 2"R lift, 215/75r15 tires, self tuned
02 allroad TDI 6MT - 150kmi, current project, getting a BSM deleted BHW and euro TDI geared 01E quattro
Scott02 is offline   Reply With Quote
Old July 7th, 2018, 21:15   #7
terrydtdi
terrydtdi's Avatar
I have a BHW manifold and the adapter plate from Darkside. Who did your tune with that turbo?
Old July 12th, 2018, 05:27   #8
Scott02
TDI(s): Too Many
Why? What do you want to know?
Old July 14th, 2018, 21:20   #9
terrydtdi
terrydtdi's Avatar
Because it sounds impressive. Curious to hear more about it.
Old July 17th, 2018, 05:14   #10
Scott02
TDI(s): Too Many
Any of the big guys will write you a good tune for a gt2256v. 26psi sustained on a stock ALH engine, excluding head studs. Turbo would easy make 18psi at 2000rpm pulling a tall 5th gear up a long grade with no problem. So it pulled hills like a stock turbo 18psi tuned car... but then would rip at/above 2500rpm with 26psi to just before red line. Pretty good turbo really. No fussing with odd actuators, actuator conversions, clocking etc. Weld up BHW/1z/AHU manifold adapter and bolt it all together with a braided oil feed and a pushlok hose oil drain.
WTB BHW Exhaust Manifold terrydtdi Private TDI Items for Sale/Wanted 0 November 18th, 2017 16:07
BHW exhaust manifold w/factory get sensor brandonfast Private TDI Items for Sale/Wanted 6 September 11th, 2017 16:36
looking for BHW Exhaust Manifold tdi CNGVW Private TDI Items for Sale/Wanted 2 November 28th, 2015 01:57
bhw exhaust manifold xcdhracer15 Private TDI Items for Sale/Wanted 2 March 19th, 2013 05:28
WTB : b5.5 BHW exhaust manifold TDIwestfalia Private TDI Items for Sale/Wanted 8 June 29th, 2012 07:22
Page generated in 0.14099 seconds with 12 queries
[Output: 100.06 Kb. compressed to 85.26 Kb. by saving 14.80 Kb. (14.79%)]
