DeliveryValve
The original VW factory recommendation on our Passat TDI timing belt change interval was 100,000 miles. Than a couple of years later VW adjusted the change interval to 80,000 miles.
My original belt, tensioner, roller, and water pump went 80,000 miles before I had it replaced along with the BS module.
There have been some discussion in the past here that you can indeed go to 100,000 miles before the TB service, and I was certainly one that was thinking I could do so with my car also.
Fast forward to 82K on the timing components. I noticed earlier this week there was a good amount of coolant leaking from the front cover of the engine. I am very surprised to see that happen with a 82K mile water pump.
Yesterday I dove into pulling the car apart and I am very grateful my water pump was leaking as I found this.
This Gates brand timing belt is cracked right where the factory joint is located. I really do think this would of snapped in no time and I would of been looking at a headache full of head work!
Here is the leaking water pump that sounded the alarm.
A pic of the just installed components. New Contitech timing belt, INA tensioner, SKF roller, and Graf water pump.
So based on this experience, do your timing belts at 80,000 miles!
