2000 TDI Golf won\'t start at random. Any help appreciated!
Hi all,
I had orignially thought this was related to the anti-shudder valve, but it no longer seems to be. As far as I can tell it is completely random.
I had a dozen failed starting attempts this morning when it was cold. The car sounds like it starts immediately (on the first turn, as usual), but only runs for half a second then shuts off. The first couple of times it took a second to shut off, after that it shut off immediately after starting.
I fiddled with the anti-shudder valve, working it open and closed, tugged on all the vacuume hoses, all while attempting to restart the car. All of a sudden it started perfectly, and it appeared that there was no problem. But I can't think of what I did to make it start.
It started on the first try after work. I drove it home, and shut it off, and restarted. It started perfect. Shut it back off, and tried to start again. The problem was back: it starts, runs for 1/2 second, and immediately shuts off. No amount of retrying will get it to start.
So I fiddled with everything, got it to start again (who knows why?!), and let it idle for a minute. Turned it off, tried to restart, and it won't start. Now it sits in my garage, not starting.
I'm frustrated! What can I do?
I have small bubbles in the fuel line, is that normal? I don't think it's a fuel deliver problem since "all of a sudden" it starts working.
I cannot find any vacuume leaks. I pulled apart the intake manifold, and it is clean except for a mild coating of soft black oil which wipes right off with my finger. I don't believe I have intake clogging problems.
What is "relay 109", could that have anything to do with it?
Please help!
Hi all,
Please help!
