Old May 25th, 2018, 12:00   #1
MichaelP
Default Smoke at startup, increased oil consumption in ALH
I have a 2000 Jetta ALH 5-speed with 269k miles. It has had a custom Kerma tune since around 130k miles. I recently had an issue with reduced power which turned out to be a bad MAF sensor, but not long after fixing that it started smoking a lot intermittently at start-up (light gray smoke with a burned oil smell) and consuming more oil. I already had a leak from somewhere around the turbo, but it was only losing about 1 qt every 5k miles, but with this sudden smoking it increased to 1.5 qts in 1000 miles. I plan to dig into it this weekend.
After reading a few threads it sounds like valve seals are an unlikely issue (due to the lack of intake vacuum). What else should I be checking? I planned to pull the tubes and check for oil in the turbo and intercooler. Before this I planned to change to a cleaned intake manifold this weekend (and still may do that depending on what I find).
2000 Jetta TDI, 5-speed, 269k miles, KermaTDI QLoader file, Der Chimera Stage II Clutch.
1995, 96, 97 Ford Powerstrokes, 1992 GMC Typhoon, 1973 Pontiac Trans-Am, 1973 Chevy Blazer with Pontiac 400, 2008 Smart ForTwo, 1974 Chevy Vega street/strip car, 1973 Chevy Vega Super-Gas drag car
MichaelP is offline   Reply With Quote
Old May 25th, 2018, 12:27   #2
steve6
this is all you really need to do "I planned to pull the tubes and check for oil in the turbo and intercooler." it will most likely contain your answer. 1 qt in 5000 miles is 'normal' or marginal, but 1.5 qts in 1000 miles is too much. Check your intercooler before it sucks in oil and causes a run away.
steve6 is offline   Reply With Quote
Old May 27th, 2018, 08:12   #3
maxmoo
Check for play in your turbo.
maxmoo is offline   Reply With Quote
Old May 27th, 2018, 20:11   #4
ghohouston
ghohouston's Avatar
Fuel Economy: 40 Mpg
If your turbo checks out, it probably is valve stem seals. You can pull the turbo/exhaust manifold and look at the exhaust valves. It will be obvious if one is leaking.
2001 Silver Jetta Sedan TDI 5 Speed,3" Kerma turbo back straight pipe
Allard EGR Delete
Bosio DLC 764's. 1997 Ford F350 CCLB 7.3 Powerstroke Diesel ZF5, straight piped
ghohouston is offline   Reply With Quote
Old June 1st, 2018, 10:24   #5
MichaelP
Thanks for the input! Intercooler and tubes have a bunch of oil in them, presumably the turbo's oil seals are worn out?
Where is the best place to get a low mileage or rebuilt stock turbo? Isn't the stock one a VNT15? I suppose I would consider an upgrade at this point, but I mostly want to get it back together quickly.
Old June 1st, 2018, 10:57   #6
flee
Fuel Economy: 40-ish
You can't go wrong with a new Mahle VNT-15.
I bought one from IDParts a few years back.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old June 1st, 2018, 12:13   #7
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Thanks for the input! Intercooler and tubes have a bunch of oil in them, presumably the turbo's oil seals are worn out?....................
That's always tricky because if the car is driven gently combustion gas precipitate will collect, it's oily. Does sound like the turbo might be leaky though, verify. Some folks get away cheap with turbo replace, more not so much.
ALH--50 RPM surge at idle, increased fuel consumption HBB TDI 101 5 September 7th, 2016 01:57
Increased oil consumption on highway? squebel TDI 101 36 September 14th, 2009 09:35
increased oil consumption post valve cleaning sdeck TDI 101 7 March 20th, 2008 07:49
Increased oil consumption since Rotella T TDIfor Fuels & Lubricants 30 April 14th, 2007 13:56
Surging and increased startup smoke Roy Basch VW MKIV-A4 TDIs (VE and PD) 8 August 27th, 2001 23:28
Page generated in 0.14725 seconds with 11 queries
[Output: 81.01 Kb. compressed to 70.47 Kb. by saving 10.54 Kb. (13.01%)]
