fouillard13
for the last while, my cars been going into limp mode around 2500RPM. checked the usuals, all came back good. im getting code p2564 = turbo boost control position. the boost controller, and its wires seem fine. wastegate is fine. MAF unplugged doesnt change anything. intercooler piping was rough, fixed, but didnt seem to change much.
have checked a few things and my mechanic finally discovered this loose fitting thats on a large vacuum line. its involved in the vacuum process and when he wiggles it, says itll adjust the vacuum that he has pulled. (its the one on the right with the hose clamp)
I am wondering if this can be tightened, or replaced? whats the fix for this? whats this piece even called?!
ive had problems with this part also back in Feb 2017.... it had leaked diesel onto a coolant line below, and was causing the coolant line to swell, degrade, and then leak significantly. ive had a new gasket waiting in the glovebox for almost 16 months now... oops.
anyways, what can be done now? any suggestions or advice would be greatly appreciated.
thanks!
thanks!
