Old May 17th, 2018, 12:56   #1
Nohlan_4
Default How to get these clamps off?
I am trying to diagnose a turbo issue with a 2006 BRM. Just wondering what tool is needed to get these hose clamps off? There are a couple of them on the compressor outlet pipe.
Nohlan_4 is offline   Reply With Quote
Old May 17th, 2018, 13:23   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Will these do it?
Recently added to my kit.
Old May 17th, 2018, 14:01   #3
Nohlan_4
Originally Posted by BobnOH View Post
Will these do it?
Link doesnít work?
Old May 17th, 2018, 15:40   #4
BobnOH
not-a-mechanic
Try "Cable-operated Hose Clamp Pliers" or just Hose Clamp Pliers.
Old May 17th, 2018, 17:07   #5
Nohlan_4
I have seen those but there isnít much to grab onto with those clips. There is no tabs?
Old May 17th, 2018, 18:13   #6
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
Were there tabs there at one point?
It's kind of fun to do the impossible.-Walt Disney
POWERSTROKE is offline   Reply With Quote
Old May 17th, 2018, 20:48   #7
KyleMillione
Fuel Economy: 02 (auto) 39, 03 (man) 48
From the picture I think thatís one of the snap in boost hoses. As far as I know you canít replace just the clamp there.
2002 Green Jetta Auto 220k RIP
2002 Black Jetta Auto 240k
2003 Silver Jetta 5sp 290k
KyleMillione is offline   Reply With Quote
Old May 17th, 2018, 21:37   #8
drucifer
From what I could see that pipe is an assembly.
If you get the clamp off what then? Either the hose itself is split or the o ring needs replaced or the nubs are worn down and not keeping a good seal. Also the alternative that the hose is fine and your problem is elsewhere.
drucifer is offline   Reply With Quote
Old May 18th, 2018, 09:46   #9
Nohlan_4
It looks like to me in order to get this pipe off the car then I need to take of that odd clamp. The picture isnt the actual picture it was only to reference the clamp. The pipe i'm talking about is compressor outlet pipe on a BRM.
Old May 18th, 2018, 09:47   #10
Nohlan_4
See above.
Old May 20th, 2018, 17:57   #11
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Just cut it and replace it with a regular hose clamp.
runonbeer is offline   Reply With Quote
What clamps to use? frosz TDI 101 18 February 28th, 2015 12:55
T Clamps vdubbintdi Upgrades (non TDI Engine related) 1 March 30th, 2013 07:49
Anyone know where to get NEMIOX clamps? phatcyclist Upgrades (non TDI Engine related) 0 November 28th, 2009 11:02
Frostheater, spring clamps or worm style clamps. Which one to use? DwightC Upgrades (non TDI Engine related) 25 February 12th, 2008 08:49
T-bolt clamps: Which ones? edfcmc TDI Power Enhancements 4 August 17th, 2006 08:24
Page generated in 0.14917 seconds with 11 queries
[Output: 100.17 Kb. compressed to 84.47 Kb. by saving 15.69 Kb. (15.67%)]
