veedubu
it is a 2011 golf tdi that came w/ factory bixenons and now i'm upgrading to LED bixenons (using factory OEM parts)... They are installed and after many, many hours of coding I seem to have all lights working, without any bulb out errors...EXCEPT the front side markers (both) are on with the drl's, and the front side markers (both) go out when you turn the headlights on.
My headlight switch and rear tails are stock... for now anyways.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AE
Coding: 6D180A3B80272A040088008170008DEC43052086534D8560E4 8020240040
Shop #: WSC 01357 011 00200
VCID: 3A55ED3FB544B89
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 22021 26 0512
Coding: 009795
No fault code found
Revision: 00104 AE
Coding: 009795
No fault code found
