Old May 26th, 2018, 06:15   #1
aktartt
TDI(s): 2000 Golf
Default Can't reproduce starts-and-dies behavior for mechanics
Several weeks ago my 2000 Golf suddenly acted up: started, then died. All the lights on the instrument panel were normal, and the so-called anti-shudder valve wasn't stuck. After about 15 tries, I had to have it towed. Once it was unloaded at the shop, it started right up and stayed running. The mechanics kept it for several days and were unable to reproduce the behavior. No codes had been thrown. So I picked it up and drove it for three days with absolutely no problems. Then on day 4 I got stranded again, tried for 15 minutes to get it to start, but it was the same thing: fired right up, then died with a slight wheeze/soft growl. Instead of calling a tow truck, I abandoned the car, then went back the next day. It started and kept running on the second try. I drove straight to the shop. Over a dozen or so attempts, it started and kept running, purring like a kitten. The mechanics say they cannot diagnose the problem until it exhibits the fires-and-dies behavior. Later that day, while I was running errands, there were a couple of times when it wouldn't stay running until try no. 4 or 5. Same behavior when I used the valet key, so it isn't an immobilizer issue. Once it's running, it never dies on me and sounds like it could go on forever.
Does anyone have any ideas? Fuel lines were replaced back in the fall, along with relay 109. Timing is right on the money, I'm told. I've searched the threads and cannot find any causes for the fires-and-dies behavior except (1) immobilizer and (2) ASV, and I believe I've ruled both of those out. The only pattern I can see is that the two times I was stranded, it was in the heat of the day, not early morning. Sorry for the long post.
aktartt is offline   Reply With Quote
Old May 26th, 2018, 09:25   #2
JB05
Fuel Economy: 43/41/40
You need to have a proper ECU scan to check for any hidden DTC's. Did your mechanics do this, and if so, what are the error codes? Check the trusted mechanics by state stickie to see who is near you.
JB05 is offline   Reply With Quote
Old May 26th, 2018, 11:51   #3
flee
Fuel Economy: 40-ish
This is possibly fuel related.
Start with a fresh filter and don't forget the thermal-tee o-ring.
If it happens again I would remove and inspect the tank pick-up.
After all these years it can get plugged with gunk intermittently.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
B4 Starts then dies. Then starts hard. Hanicus VW MKIII-A3/B4 TDIs 18 October 24th, 2013 07:45
Starts and Dies badshaw24 VW MKIV-A4 TDIs (VE and PD) 0 December 12th, 2011 07:52
starts then dies larsbar TDI 101 14 November 1st, 2007 13:34
Starts, dies, starts, dies:( HELP! vwjettadsl TDI 101 22 November 7th, 2005 20:02
Starts and then dies DZLPWR 7 VW MKIV-A4 TDIs (VE and PD) 3 March 12th, 2001 20:06
Page generated in 0.13732 seconds with 13 queries
[Output: 58.21 Kb. compressed to 53.02 Kb. by saving 5.20 Kb. (8.92%)]
