newlitemotorist
I wanted to share a little project I had been pondering for a while which I was able to implement this past weekend. In an effort to resolve a small oil consumption issue I have traced it down to two probable causes as there are no external leaks. Oil is more than likely making its way past my rings, this car is an old man after all. I also have a bit of oil (any at all is more than I want) making its way into my intake, probably a few ounces every 3-5k miles. I had wanted to install a pro vent but I'm cheap and I like to create my own solutions. Another concept I wanted to implement was positive crankcase ventilation. Creating a vacuum inside the crankcase helps reduce windage losses and in my case, I hope to improve ring seal even if its marginal. The exhaust driven ccv systems are tried and ehh (1-3 in-hg at best) so I wanted to either install an actual vacuum air pump ($$$) or try another method which works only if you have a turbo. Just before the turbo inlet there is vacuum. With a stock intake system and paper filter I am guessing it produces enough (untested, speculation) to meet my goals which is why I chose this route. I set out to improve the factory oil catch while eliminating the control valve and improving flow volume. Enjoy!
I've had this cracked brm valve cover laying around for too long but before I tossed it I decided to investigate. Here is what's inside.
