Guys,
In Germany they have the Centurion (Thielert) 4 cyl 135HP diesel engine, it's a converted Mercedes car diesel, 4stroke 4cylinders; kinda heavy. Clean/Installed weight is 135/180Kg. Power to weight ratio is rather low and in test aircraft it performs marginal in the climb performance department.
In France they have the SMA 305 diesel, 4 cyl, air oil cooled engine of around 230 hp weighing 192 kg, this should be a winner, i think.
Personally I'm building a Pelican PL, this a/c should get a Wilksch WAM-120 120HP / 100Kg, 3cylinder 2 stroke engine and will perform like any other Pelican PL with 120Hp (still in final building fase,no test data) and with another friend i'm working on a RV7A which should get Wilksch WAM-160 engine, basically the same as the WAM-120 only with 4 cylinders.
The Centurion and SMA engines are electronically controlled and the Wilksch has a mechanical fuel controller.
These engines are designed or modified to run on JET fuel.
see for more info on websites:
http://www.centurion-engines.com/
http://www.smaengines.com/
http://www.wilksch.com
As far as I know Lycoming and Continental should have a running diesel engine aswell; but I'm not sure how far they are in development.
Take care
John
