golfere
After about $2500 in parts these past months including turbo, cam, timing belt, tandem pump, egr valve, filters clutch/flywheel and oils...
im still getting around 36mpg - 37mpg and the car still has a hesitation in the 2k rpm range where the car literally shudders and "misses" until higher rpm is reached - When my EGR is unplugged it doesnt shudder at all; Even with a brand new EGR it shudders...any ideas? torsion value? ASV?
Im assuming the DMF is toast as when i press in the clutch a bit it rattles very loud so i have a new clutch and flywheel in stock
It leaks oil a few drops a day but how do i check if it needs a new rear main seal?
Around the headgasket its wet but would this mean my headgasket is going?
Tie rods are due for replacement and so are the CV boots (also needs alignment so after all this ill bring it to the shop
Knowing what i mentioned would you sell the car? Im willing to fix it but i have no ideas what else the problems are with the hesistation, oil leak, head seepage, etc but i can take photos if needed as i want to get this resolved just need your help
Many thanks in advanced
