Old December 13th, 2017, 13:40   #1
gords@shaw.ca
TDI(s): Golf
Default No key at wrecker's... how to move Tiptronic shifter to neutral?
I'm going to the wreckers to check out some Golfs and Jettas that have a similar Tiptronic shifter that I have in my 2005 Golf TDI.
To pull the console off at the wreckers it seems I'll have to move the shifter to the neutral area. How can I do this when there's no key in the ignition.
I need the shifter guide out of one of the wreckers cars as mine got scrunched up.
gords@shaw.ca is offline   Reply With Quote
Old December 13th, 2017, 14:09   #2
najel
Pull the shift boot trim (just pull up on it, it unclips), there is a yellow deal with a release at the front of the shift mechanism.
Stole this picture from here, it's from a Passat, but it's pretty much the same.
najel is offline   Reply With Quote
Old December 13th, 2017, 14:48   #3
gords@shaw.ca
TDI(s): Golf
Thanks!
Old December 13th, 2017, 14:55   #4
najel
Just thought of this, what I said applies to Mk5, I would assume Mk4 is similar, but I'm not sure. You said 2005, so for some reason I assumed Mk5, but it could be Mk4 you're asking about.Hopefully someone who knows for sure can chime in.
Old December 13th, 2017, 15:27   #5
compu_85
Gadget Guy
compu_85's Avatar
It's similar on the Mk4's. There's a release under the shift boot.
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
compu_85 is online now   Reply With Quote
Trouble pushing down on shifter into neutral Shouse VW MKIV-A4 TDIs (VE and PD) 14 October 13th, 2017 07:03
Broken tiptronic shifter? Anyone seen this before? AARodriguez Corp. VW MKIV-A4 TDIs (VE and PD) 2 December 25th, 2013 20:25
put shifter in fifth gear and its like its in neutral Camaroraca TDI 101 3 March 4th, 2013 09:10
F/S: MKIV Tiptronic shifter assembly and a B5 shifter guide strip bradleyb1 Private TDI Items for Sale/Wanted 2 October 15th, 2012 08:27
Unable to move manual shifter out of gear DJGeorge VW MKIII-A3/B4 TDIs 7 December 19th, 2004 20:58
Page generated in 0.13986 seconds with 11 queries
[Output: 69.37 Kb. compressed to 61.62 Kb. by saving 7.75 Kb. (11.18%)]
