Old December 12th, 2017, 15:01   #1
mcarthur70
Fuel Economy: 48-50
Default 03 alh not starting at a loss..
I posted in another thread that was related to mine ..But didnt want to high jack it . so here goes drove it home friday no problems . We had a cold spell over the weekend and never drove until monday mourning . It wouldn't start . when i got home it was 50 degrees out side and still no start . so i changed the fuel filter pre filled it with fuel checked the asv and it was good . checked the fuel shut off valve im getting 10.62v when the key is turned on . No evidence of fuel leaking at injection pump ,was replaced at 105000 miles it has 190253 now . Loosened the nuts at the top of the injectors some fluid comes out when cranking but not alot . im going to check vacuum from tank to filter ,then from injection pump will keep you posted .Anything esle to check will be appreciated ! thanks
mcarthur70 is offline   Reply With Quote
Old December 12th, 2017, 15:03   #2
mcarthur70
Fuel Economy: 48-50
also could the fuel pick up be stopped up in the tank ? is this common or uncommon ? thanks
Old December 12th, 2017, 15:16   #3
RallySport
RallySport's Avatar
Fuel Economy: 42-50.5
Your car does not have an electronic fuel pick up in the tank.
RallySport is offline   Reply With Quote
Old December 12th, 2017, 15:27   #4
mcarthur70
Fuel Economy: 48-50
i know that but can the pick up get clogged up ?
Old December 12th, 2017, 15:59   #5
chz17
It's possible, you may check it, the fuel sending unit are under the back seat. Make sure the fuel are less than half tank when do it. Have you been check the timing belt system? Oh and make sure ASV are open when trying to start engine.
chz17 is offline   Reply With Quote
Old December 12th, 2017, 16:23   #6
maxmoo
Yes and it is fairly common, see below....
https://www.youtube.com/watch?v=yRMTEAKsScE
http://forums.tdiclub.com/showthread.php?t=68872
maxmoo is offline   Reply With Quote
Old December 12th, 2017, 17:29   #7
mcarthur70
Fuel Economy: 48-50
i bleed the injection pump the beast started right up .. she's growling again !!!
Old December 13th, 2017, 07:10   #8
RallySport
RallySport's Avatar
McArthur! When you bled the injection pump, did you have the key on?? Or were you able to bleed it with the ignition OFF??
Still waiting for my starter motor...
Old December 13th, 2017, 09:30   #9
jokila
jokila's Avatar
Fuel Economy: 52/45/40
"Things that go away by themselves, come back by themselves..."
You most likely need to install one of these:
https://www.idparts.com/tdi-injectio...lh-p-1143.html
as the seals are getting old.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old December 13th, 2017, 09:42   #10
jokila
jokila's Avatar
You don't need to have it on. If it has a placebo effect for you then do so, but there is nothing to stop the flow otherwise.
I've done this procedure many times and it's a completely manual process to get fuel through the IP.
03 alh power loss engine lugging. Please help! makos101 TDI 101 4 January 28th, 2016 12:57
Extremely hard starting 03 ALH w/ VAG-Com 17656 Code ADVNTURR VW MKIV-A4 TDIs (VE and PD) 12 June 26th, 2015 11:13
03 GLI FS3 Brakes fit on 1.9 ALH 03? ko2222 VW MKIV-A4 TDIs (VE and PD) 1 March 19th, 2015 06:11
03 jetta alh Not starting Ryderfzr VW MKIV-A4 TDIs (VE and PD) 9 February 18th, 2012 09:25
Power loss / no turbo for a few minutes after starting Bokonon TDI 101 5 February 6th, 2009 08:24
Page generated in 0.13440 seconds with 11 queries
[Output: 95.50 Kb. compressed to 81.36 Kb. by saving 14.14 Kb. (14.81%)]
