tamoshanter
Hello,
Driving to work today, I am used to the time it normally takes for the washers to work, but pulling back on the stick, no noise, and the wipers didn't come on. Same with the rear wiper/washer. No washers
However, the wipers work fine if I'm not working the washer part. They come on, intermittent, normal and fast. Rear works no problem. Just when I try to use the washers they don't work , neither front nor rear.
Any ideas? is there a separate fuse for the washers WITH wipers, as opposed to wipers OR washers?
Please help, as it's -12c and I will need to drive home at some point!
