Old December 10th, 2017, 15:05   #1
atmarine
Default Parking Brake cables
Recently with the cold weather I have been suffering with frozen E-brake cable on the passenger side.
I have replaced my parking brake cables about 20K ago. They are in good shape, and the boot end is intact with no rips, cuts, etc. I have popped off the cable from the caliper to confirm it is the cable and not a sticky e-brake lever on the caliper.
Is there anything I can do from here, or replace them again?
atmarine is offline   Reply With Quote
Old December 10th, 2017, 16:37   #2
wonneber
ID-Parts has helper springs to retract the e-brake arm.
Did you get the new heavier e-brake cables and hardware?
Old December 11th, 2017, 00:30   #3
hey_allen
I'll second the helper springs for the MK4 cars.
I just did this job last week, on a friend's car, that had new cables on it 6 months ago.
Adding the helper springs (unfortunately sourced from a local dealer, due to shipping time) did fix the issue, and he's had no frozen brakes since.
hey_allen is online now   Reply With Quote
Old December 11th, 2017, 17:56   #4
atmarine
Thanks all,
I'll check the return springs before replacing the cables again.
Old December 11th, 2017, 21:11   #5
Caddy 16v
Caddy 16v's Avatar
Had the same issue but didn't catch it in time. My parking brake was half engaged on one side and wore the pads to the metal, also trashed the caliper in the process. Unhooked it for now but might have to look into the heavy duty solution as well.
2000 Jetta, mufflerectomy, Evolution Atlas skid plate, OEM xenon reps retrofitted, Hella Micro DE, HFLOX Warp 3 nozzles, 3 bar map, Malone Stage 5 Custom, Euro 17/22, DC Stage 4 clutch, STAGG suspension, Curt hitch, Auber EGT and NSP boost gauge, Hella Sharptones, Rally Armor mud flaps, 1.8T pancake pipe, upgraded SMIC, VAG-COM, all offroaded out
2000 Golf, JSP Armadillo skid plate, limo tint (Sold)
Caddy 16v is offline   Reply With Quote
Old December 12th, 2017, 08:44   #6
wonneber
It was one of the easiest upgrades I've done.
The rear pads on my Tiguan were froze in the slides and wiped out in 30K miles.
Front brakes are like new.
Replaced parking brake cables - parking brake won't engage! Kentonius VW MKIV-A4 TDIs (VE and PD) 4 December 15th, 2012 18:11
Parking brake cables? supton VW MKIV-A4 TDIs (VE and PD) 7 February 13th, 2012 17:59
Parking brake cables shagin'wagen TDI 101 14 February 23rd, 2010 19:01
B4 parking brake cables lupin..the..3rd VW MKIII-A3/B4 TDIs 9 September 11th, 2008 16:47
Parking Brake Cables Brian_Spilsbury VW MKIV-A4 TDIs (VE and PD) 3 August 21st, 2007 13:18
Page generated in 0.16362 seconds with 11 queries
[Output: 72.76 Kb. compressed to 63.80 Kb. by saving 8.96 Kb. (12.32%)]
