Old December 12th, 2017, 14:47   #31
mcarthur70
Fuel Economy: 48-50
well after getting the car in the garage , i noticed that a mouse or a squirrel has chewed my hood insulation right over the top of my air filter intake box and made a big hole in it ! is there anything on the drivers side that might have been chewed on that might not let this car start ? like wires to something to maf or anything you guys can think of ? thanks for the help
mcarthur70 is offline   Reply With Quote
Old December 12th, 2017, 14:59   #32
Rxfire
Rxfire's Avatar
I guess we have 2 "No Start" cars in this thread...
The Injector Pump seals issue hits every fall/winter. Look under the Injector Pump, almost behind and below it. See any "pooling" of fluid in the little grooves? See any spots of fuel on the coolant hose? If you prime the pump, and then crank the car with injector nuts loosened, and it does not squirt out of the injector nuts area, the fuel has likely not stayed in the pump due to seals leaking.
For mice in cars (also available on Amazon, etc etc):
https://www.earthkind.com/fresh-cab/
2 each 2003 GLS Jetta Wagons (White/tan leather and White/black leather), 5 speeds, Panzer plates, roof rack cross bars (hers), homelinks, 520 nozzles, ventectomies, trailer hitch (mine), VR6 front springs (hers); 1 inch lift kit w/ESP (mine) 1986 Isuzu Trooper Turbo Diesel, 1985 Isuzu P'up NA Diesel
Rxfire is offline   Reply With Quote
Old December 12th, 2017, 15:27   #33
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Originally Posted by mcarthur70 View Post
Yes i pre filled the filter .. pulling it in the garage and go over everything under the hood .. was to dark last night .. maybe i can find whats going on with it .. i also checked the timing belt it is in tack. 190000 miles never had any trouble like this before. Another question , when you loosen the fuel lines at the top of the injectors and you crank it i am getting fuel bubbling out of all 4 injectors . or should it stream out ? thanks for the help..
I am gonna say it since you are a newbie...
You should start your own thread. You will get more help than hijacking one.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old December 12th, 2017, 15:43   #34
mcarthur70
Fuel Economy: 48-50
well there is not any evidence of a leak at the injector pump .. it was replace 105000 miles . my next step is to pull a vacuum from tank to filter . and see if i get fuel . the injector tops are not leaking a lot of fuel when i loosen them just a little . can the pick up in the tank be clogged up and preventing fuel to get picked up? is this rare or common ? thanks
Old December 12th, 2017, 15:44   #35
mcarthur70
Fuel Economy: 48-50
ok i didnt mean to hihg jack this , we are having the same problems just thought we could help each other . ill start a new one .
Old December 12th, 2017, 15:48   #36
wonneber
Is there anything on the drivers side that might have been chewed on that might not let this car start ? like wires to something to maf or anything you guys can think of ? thanks for the help
I would think any electrical issues would throw a code.
Maybe check getting power to the solenoid on the injection pump while the engine is cranking.
Old December 12th, 2017, 16:21   #37
RallySport
RallySport's Avatar
Fuel Economy: 42-50.5
Pulled the starter out just now. Piece of cake when you know what you're looking for.
The positive battery cable lead to the starter looked like it had some corrosion on it so I will be cleaning that up before I install new starter.
More to come. Stay with me
RallySport is offline   Reply With Quote
Old December 18th, 2017, 05:55   #38
RallySport
RallySport's Avatar
Threw a starter in the car. Still could not pill fuel through to the injection pump. So from my diagnosing I believe I need injection pump seals. I brought the car to the nearest TDICLUB certified mechanic.
Martin Bergel LLC in fowlerville Michigan. I talked to Marty and he also thinks the IP seals are the culprit but he is going to go through all of the things I went through already to make sure I didn't miss something.
I'm also having him put a TB in the car since he only wants 200 bucks. He's going to do the IP seals out of the car, and put a TB in for 450 labor I have to supply all parts. So for about 750-800 bucks I should have this all fixed with a fresh TB. I don't think he's touched my car yet since I don't have the parts yet. I will let you guys know what he finds.
Thanks for everyone's help.
Old December 18th, 2017, 18:45   #39
wonneber
Don't forget to let us know this works out.
Old December 19th, 2017, 05:48   #40
tdibiznis
Yeah let us know
tdibiznis is offline   Reply With Quote
Old December 19th, 2017, 13:23   #41
jokila
jokila's Avatar
You are welcome on the diagnosis.
Old December 19th, 2017, 15:37   #42
tdibiznis
Unhappy
Should I start a new thread or can I ask my question here? I have a 2002 jetta tdi alh sedan. Kinda the same problem as Rallysport.
Old December 19th, 2017, 15:52   #43
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Only because this thread seems a bit scattered and is still active I think, Start a New Thread.
Old December 20th, 2017, 05:55   #44
tdibiznis
Thanks I'll do so 👍
Old December 21st, 2017, 08:49   #45
RallySport
RallySport's Avatar
Talked to Marty, I believe he is a TDIClub member, but dont know his alias. He told me he is also sucking air though the pump(not fuel) so he will be replacing IP seals, and getting a timing belt while hes in there.
THANKS JOKILA! I will let all of you know if the IP seals fixed the no start problem. So anxious!
ALH Cranks, but won't start. duck-duck-dub TDI 101 5 March 15th, 2015 15:32
2002 tdi golf cranks but won't start cfuzz987 VW MKIV-A4 TDIs (VE and PD) 5 October 6th, 2014 18:06
2002 Jetta cranks but no start SummerSmoke VW MKIV-A4 TDIs (VE and PD) 10 May 2nd, 2014 08:32
'00 ALH Cranks but won't start Matdman VW MKIV-A4 TDIs (VE and PD) 14 May 25th, 2013 19:19
2002 TDI Wont Start (cranks over but wont run) snocrossmechanic VW MKIV-A4 TDIs (VE and PD) 8 October 29th, 2005 17:15
Page generated in 0.19375 seconds with 11 queries
[Output: 127.20 Kb. compressed to 106.52 Kb. by saving 20.68 Kb. (16.26%)]
