Old December 10th, 2017, 13:52   #1
dave69
TDI(s): 06beetle
Default 06 beetle so many codes
I am working on my daughters 06 beetle,it has been sitting for a while the battery went dead,I charged it up,when I started it I noticed it had the cel on as well as a flashing glow plug light.when I connected my scan tool to it it came back with 7 codes 3338,3373,0245,3101,1495,0322,0341.all these code seem to be electrically related,the car seems to run fine.My question is ,is this normally what happens when the battery goes dead?should I drive the car for while to see if these codes disappear,or am i checking all connections?any help would be great,i am not familiar with these cars
dave69 is offline   Reply With Quote
Old December 10th, 2017, 14:09   #2
Tdijarhead
Dead battery throws a bunch of codes. Clear them and see what comes back if any.
Tdijarhead is offline   Reply With Quote
Old December 10th, 2017, 17:58   #3
dave69
TDI(s): 06beetle
I cleared the codes,I started with 8 and 7 remained,I checked and cleaned every connector I could find under the hood,took the car for a 5 mile ride ,reconnected the scanner and got the same 7 codes.the flashing glow plug light only flashes when key is on ,engine not running
Old December 11th, 2017, 03:36   #4
Tdijarhead
http://wiki.ross-tech.com/wiki/index...P0119#mw-pages
Ross-tech is the manufacturer of the vcds cable and they keep a pretty comprehensive list of fault codes at their site. I couldn’t find any of yours listed. What are you using for a scanner?
Under the battery there are several grounds that are problematic to the 06 model year. Pull them apart and clean them up. Doing that requires removal of the battery.
Old December 11th, 2017, 08:28   #5
jokila
jokila's Avatar
Fuel Economy: 52/45/40
He needs to find someone with a VCDS.
Where in the great white north do you live?
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is online now   Reply With Quote
Old December 11th, 2017, 08:43   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I had this happen once with a VCDS, wish I could remember exactly what it was. Could have been I had the wrong label file, but IIRC it was maybe the port?
With the OBDII reader attached, try running the self-test/learning function to verify settings.
Old December 11th, 2017, 15:50   #7
dave69
TDI(s): 06beetle
The scanner i am using is a autel maxidiag elite ,I am not experienced at any of this so bear with me ,I have cleaned those ground connections under the battery along with every other plug in connection I could find under the hood,I checked glow plugs for resistance,they were all the same, .8 ohms ,I will check for power to glow plugs,checked all fuses with test light all good ,never pulled them,might try that. The car runs so good I can't believe all these codes exists. I am not too familiar with this scanner,I borrowed it from a co worker but I will see if I can figure out this self testI live just outside of Windsor Ontario ,south of Detroit mi. Thanks for all the help
Old December 11th, 2017, 16:05   #8
dave69
TDI(s): 06beetle
Just checked,no power to glow plugs
Old December 11th, 2017, 17:17   #9
Tdijarhead
Depending on temperature the power to the glow plugs will only last a few seconds at most and 10ths of a second on a warm engine. I’m thinking you’ll need to find someone with a vcds and ditch the autel.
Old December 11th, 2017, 19:08   #10
wonneber
If you unplug the coolant sensor the ECU will think its 34 below and the glow plug light on much longer for testing.
Old December 12th, 2017, 14:04   #11
dave69
TDI(s): 06beetle
I'll try that with the temp sensor thanks
06 jetta swap with 06 beetle Nickf TDI Conversions 1 August 9th, 2016 19:46
Fault codes 06 TDI sonspot VW MKV-A5 Golf/Jettas 3 April 3rd, 2015 08:58
06 DSG codes/issues.. please help.. TDIJetta99 VW MKV-A5 Golf/Jettas 14 October 28th, 2010 13:59
substitute '06 beetle radio in '03 beetle? sch8489 Upgrades (non TDI Engine related) 0 January 14th, 2007 21:36
06' New Beetle w/DSG vs. 06' Golf Auto larez TDI 101 12 May 12th, 2006 08:24
Page generated in 0.15323 seconds with 11 queries
[Output: 97.42 Kb. compressed to 82.32 Kb. by saving 15.10 Kb. (15.50%)]
