Can't adjust IQ in VCDS adaptions
2000golftdigls
Rockport, MA
2000 Golf TDI GLS
When going into the adaptions mode of VCDS, I can only adjust idle in group 2. All other groups are " Not Available". Anyone else have this problem? I want to adjust IQ. It is presently at 1.8 and I have slowdown shudder. I bought the unit from Rosstech and paid full price.
Mongler98
COLORADO (SE of Denver)
*paid full price*, glad to see a good buisness getting its money. I paid $55.00 for mine used, works as good as yours!
What engine code is your engine? Some engines need to be manually adjusted, some with a "hammer mod"
South of Boston
Did you log into adaptations? 12344 is the login, IIRC. After logging in you can change settings.
South of Boston
On the same screen where you select Adaptation there's a log-in bar. Click on that, log in (it's 12233, not what I posted above) and then go back to click on adaptation. Go to field #1 and you can adjust IQ.
I was looking for an article describing this. There should be several but I can't find one, even the one I wrote years ago for our blog.
2000golftdigls
Rockport, MA
2000 Golf TDI GLS
Thanks to all for help, especially IBW. I was able to adjust the I.Q. from 1.6 to 3.0 and the shudder appears to be gone!
South of Boston
Glad you were able to do it. The older ALHs (99.5s and 2000s) can get slow down shudder when the weather gets colder.
