Old December 9th, 2017, 03:08   #1
tkoivuro
Default MK IV Variant drivers side door stuck
So I have 2001 Variant TDI and trouble is i cannot open drivers side door. The door does lock/unlock with key or central lock just fine. Both handles make that normal "door opening sound" and have some resistance when operated but the door will not open.
My guess is that the latch is just not releasing from striker. No amount of bashing, cursing and violence seemed to help.
How do i get the door opened? Climbing in from passenger side gets really old really fast
tkoivuro is offline   Reply With Quote
Old December 9th, 2017, 18:39   #2
wonneber
I've worried about this happening.
Did you try lifting the door (open the window) while someone works both handles & bumps the door a bit?
My top hinge is bad and the door hangs down a tiny bit. Maybe your door is putting to much pressure to release.
I think I would take the seat out to get the inner door panel off to get in there.
Should be able to get the regulator off at that point.
Not sure how different the Golf Variant is.
Old December 10th, 2017, 17:59   #3
where2
where2's Avatar
On mine, a good solid thump of a fist on the sheet metal of the door seems to jostle something and allow it to open. Driver's side front, Driver's side rear, and sometimes the passenger rear have been sticky at times. Driver side front is about every other day...
'06 Jetta_TDI Pkg_1 5spd (4 wife) Got Boost... 155k
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 222k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old December 11th, 2017, 12:12   #4
ItAintRodKnock
TDI(s): 01GolfTDi
Fuel Economy: 40 with lift
As where2 stated, I also fist bump my drivers side handle, passenger front and rarely drivers rear.
I made it a rhythm, unlock with key fob, bump handle with pinky side of a fist and open door.
I have dealt with this for months now but recently read a post to lube the catch area(I used Fluid Film) and now it even occasionally opens without a fist bump. Ended up lubing my hinges for all doors, trunk and hood at the same time.
From FLA to CO!! 2001 Golf 4 door White: R520, Malone 2, McNally gauge, SB stg2E clutch, Panzer FMJ, FrostHeater, 2white2blue Moog 81055, Bilstein TC-s, homemade "$40 2 inch lift" Long time poster, now just a lurker.
ItAintRodKnock is offline   Reply With Quote
Old December 11th, 2017, 18:54   #5
wonneber
Are you saying you bump the handle you pull, not the door skin?
Old December 12th, 2017, 10:17   #6
ItAintRodKnock
TDI(s): 01GolfTDi
That is what I do, I believe where2 indicated he hits the door sleeve. Personally, I find that bumping the handle works for me.
Also, I started soft and worked up to how hard I have to hit it; honestly, its a firm bump at most.
Surprisingly takes a slight bump really.
MK IV drivers side window switches 737tdi TDI 101 1 September 15th, 2013 10:26
WTB: Mk IV Left side mirror, white QuickWrite Private TDI Items for Sale/Wanted 5 March 3rd, 2013 20:28
Wanted: MK IV front end pieces, black drivers seat. Portland, OR hartung Private TDI Items for Sale/Wanted 0 October 18th, 2011 16:55
Mk 4 Jetta bumper grille drivers side r72gsaol Private TDI Items for Sale/Wanted 0 December 28th, 2010 09:07
WTB reflex silver jetta Mk IV hood and front drivers fender one.nine Private TDI Items for Sale/Wanted 0 February 18th, 2009 11:01
Page generated in 0.14184 seconds with 11 queries
[Output: 74.97 Kb. compressed to 65.79 Kb. by saving 9.17 Kb. (12.24%)]
