Old December 6th, 2017, 16:50   #1
Nero Morg
Default Boost issues
Hey all, still doing a slow revival of this car, can anyone make sense of this graph and the strange boost issues I'm having? Already done everything except check actuator rod travel. I'm about to do that, but wanted to get some $0.02.
Nero Morg is offline   Reply With Quote
Old December 6th, 2017, 17:03   #2
Nero Morg
I may have answered my own question lol I checked movement, still easy travel since I cleaned it last week, but the rod starts moving the second I pump, maybe 1psig, and stops moving at 12psig. Looks like I need to adjust it and follow up
Old December 11th, 2017, 11:14   #3
Nevada_TDI
Yes, having your actuator set to start moving at 5" of vacuum (not PSIG) and hit the stop at 18" is a good place to start. At full throttle in 3rd gear you optimally want your N75 valve % to be around 65%.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old December 11th, 2017, 18:50   #4
wonneber
Someone will correct me if I'm wrong but if green is actual boost and yellow is requested boost (on the graph) I don't think you are getting boost.
Get the adjuster close to the vacuum range above as a start then refine it later.
When I replaced my actuator I think I checked it & it was close.
I found & was getting 20 to 25 LB boost easily and had a few limp modes.
I had to lengthen the arm a few times but now I can still get 20 LB with a moderate takeoff.
Will lengthen it again at my next oil change.
Old December 12th, 2017, 10:42   #5
JB05
Fuel Economy: 43/41/40
Did you check for any DTC's(digital trouble codes)?
JB05 is offline   Reply With Quote
Boost issues Gasfarmer VW MKIV-A4 TDIs (VE and PD) 11 October 5th, 2014 17:57
Boost Valve and Boost Issues jwweatherman TDI Power Enhancements 21 January 31st, 2011 21:34
boost issues Sonic_Sound TDI 101 9 March 14th, 2010 11:33
boost presure/ boost issues AHU b5 audi simyboye TDI 101 8 April 13th, 2008 11:47
Boost Issues... Mark R TDI Power Enhancements 1 February 28th, 2003 11:18
Page generated in 0.12691 seconds with 11 queries
[Output: 66.25 Kb. compressed to 58.60 Kb. by saving 7.64 Kb. (11.54%)]
