Old December 10th, 2017, 10:53   #31
UhOh
UhOh's Avatar
It's Frank"oh"6 (not Frank"zero"6).
Old December 10th, 2017, 15:07   #32
[486]
TDI(s): 02 golf ALH
Originally Posted by Genesis View Post
(just don't turn it CCW!)
nothing in there cares what way you turn it
[486] is offline   Reply With Quote
Old December 10th, 2017, 15:33   #33
Tdijarhead
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
Tdijarhead is online now   Reply With Quote
Old December 11th, 2017, 11:06   #34
Genesis
Fuel Economy: 53/48/42
Utterly true but if you break free the bolt by turning it CCW and lose the indexing, as that's a morse-taper joint (not keyed) YOU will care.
Genesis is offline   Reply With Quote
Old December 11th, 2017, 15:48   #35
wonneber
I thought the belt tensioner may care as well.
Old December 11th, 2017, 16:22   #36
Genesis
Well yes, but in this case I was assuming (since the belt is shredded) the tensioner doesn't care any more :-)
Old December 11th, 2017, 18:23   #37
[486]
TDI(s): 02 golf ALH
It is not a morse standard taper, not even stub-morse.
It's also torqued quite a bit tighter than you can get without counterholding the pulley, even with the belt on and pulling against the friction of the whole motor, besides when loose it takes a good amount of hammering to get the taper loose.
I bump start my car every day, quite a few times I've gotten to the bottom of the driveway before figuring out it was in first rather than reverse. That's an awful lot of backwards.
ACV timing jumped ewenmaclean VW MKIV-A4 TDIs (VE and PD) 11 July 1st, 2016 03:11
Jumped Timing Belt fisherdanski VW MKIV-A4 TDIs (VE and PD) 30 April 22nd, 2013 22:34
timing belt jumped help! negcold TDI 101 32 February 7th, 2013 14:55
Might have jumped timing..... Neukom720 VW MKIV-A4 TDIs (VE and PD) 21 November 19th, 2011 08:05
Timing jumped massively all on its own... ??!?!?!?! jackbombay VW MKIV-A4 TDIs (VE and PD) 33 October 8th, 2006 19:27
Page generated in 0.13826 seconds with 11 queries
[Output: 81.77 Kb. compressed to 71.27 Kb. by saving 10.49 Kb. (12.83%)]
