Old November 21st, 2017, 11:27   #31
Nevada_TDI
Having literally gone through that exact kind of noise this past week, the problem was the distribution valve in the pump head. After having the nozzles brought to where they are within (hopefully) perfect tolerance, an error in the pump will be magnified.I had a loud "tink, tink, etc. coming out of what sounded like the #1 cylinder valve cover. I replaced the DV and the noise in that cylinder went away. The difference between us is I just had my pump rebuilt, and you did not. When IP are rebuilt, the DV's are seldom changed when the pump passes through all the tests that are run on it. If you can pull the injector line off of the injector, and remove the DV from the "noisy" cylinder and swap it with a different cylinder and the noise moves, it is the DV, if not well then it may be an injector/nozzle issue. This is the most comprehensive advice I can suggest.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old November 21st, 2017, 13:18   #32
PB_NB
PB_NB's Avatar
Were the copper injector seats changed with new ones? Perhaps not (old ones used?) which seems to explain why you were seeing bubbling around the injectors.
Why was "never seize" used anywhere near the injectors? You don't want that stuff near or in the injectors, or use it as a sealer for the copper seats.
When I changed my nozzles the first time, I went with cheap .205's and did the swap myself. I was lucky that it worked out great with no pop testing. When I went to the 1019's I sent my injectors to DBW and had them calibrated as well. Took some time and they work great. Both times I changed the seats with new ones. I did see a little leak which showed up as soot around the injector. Gave that injector a love tap and that leak went away. There was a ticking sound that seemed to be associated with the leak.
It is very important that the seats and the injectors are mated as these can leak and your compression will be thrown for a loop. Using old seats will have imprints from the previous install. The ticking sounds could also be these seats leaking as a leak directly from the cylinder can cause noise.
Could it be as simple as putting a new set of seats and gently "tapping" the injectors into these seats for a proper fit?
The jumping IQ values are a concern as well. Did you try "hammering" the IP to see if you can smooth out the fluctuations in the IQ? There is a used IP for sale for $200 locally, I am not sure about the condition but it could be worth the small investment to see if your current IP is failing.
http://dubberz.com/forum/mk4-parts/alh-injection-pump-200-obo-leather-center-console-$40/
Sounds like we need a local GTG where we can all poke around each others cars and solve all the issues
Maybe we can encourage Owain and Mark to host it at their location? Maybe we can get the Dyno out and the BBQ too.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old November 22nd, 2017, 14:00   #33
Owain@malonetuning
Paul @ autobahn dismantlers did the install, he's been dismantling VWs out of that shop for over 20 years and is a hardcore fanatic, dailies a tdi. Simon on the corner has a bosch pop tester that was used on these and said they popped off fine. Seems it's either the injectors, or you got really unlucky and the QA inside the pump failed at the same time. I've got untested 11mms kicking around but that doesn't really help and haven't got the time to work on our cars let alone customers.
Sounds like a time for dyno + BBQ, hope you have some umbrellas! Unfortunately Mark and I don't get much time to work on cars and are typically working weekends as it is just to keep up, so won't be doing much wrenching. We typically have to outsource mechanical work , hopefully some things we're working on will improve time efficiency.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old November 22nd, 2017, 18:34   #34
PB_NB
PB_NB's Avatar
Hi Owain, I know Paul and he is top notch, i bought a 2.0 for a swap from him a several years ago. Maybe the IP is failing or has some issues brought on by the larger demand of the .216 nozzles.
Perhaps a GTG will work out but it should work with schedules etc... Let us know some potential dates and I can bring the BBQ It would be great to see your dyno in action too.
Old November 22nd, 2017, 19:21   #35
vanbcguy
vanbcguy's Avatar
You can't test 2-stage injectors on a pop tester. All you can do is see where the pilot spray starts, not the main injection. I would not consider that to be a reliable test in any way.
Drop the injectors with NW, they're like 20 mins from there... They can check and service your pump too if that becomes necessary.
Sent from my LG-H873 using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old November 22nd, 2017, 20:38   #36
burn_your_money
I just went through similar issues on my car. Try getting your hands on VCDS and adjust the IQ all the way up and all the way down to see if you can find a spot where it's happy. I wouldn't suggest the hammer mod. Mine was a total pain to set and I'm pretty sure it's because the pump is on it's last legs.
I was only resealing mine.
I buy core TDI pumps. PM me for details
burn_your_money is offline   Reply With Quote
Old November 27th, 2017, 20:02   #37
munly
Just an update. I brought my car to NW Fuel Injection in Surrey. Landis is the shop manager there. He has a built VW ALH as well. He removed the injectors and tested them. Three of the four injectors were way off...spraying above and below spec. The injectors were rebuilt and calibrated. They were also cleaned of the anti seize and other dirt/carbon. The bores were cleaned as well. He said everything was quite dirty and it would be difficult for an injector to seat in that environment. He also replaced the return fuel lines. I thought the shop that originally installed my nozzles did this but they only replaced one small section between the 1st and 2nd injectors.
Anyways, the difference is night and day. The car runs great. Excellent, smooth power. I'm super impressed with the service from NW...top notch. I've learned cleanliness is of the upmost importance when dealing with your fuel injection.
I'll contact Owain and see if I can log the data we tried to gather when I first purchased the tune.
Up next VNT 17 and exhaust...thanks for all the input and listening to me complain.
munly is offline   Reply With Quote
Old November 28th, 2017, 08:51   #38
Nevada_TDI
A VNT-17 and .216 nozzles will make a metric ton of power. Okay maybe not a metric ton, but I am not allowed to write a$$ load of power anymore. Which takes me to the thought of the butt dyno; 24 PSI of boost with those nozzles will run so much better than one would think possible. When you get the chance, you may want to check the fuel sending unit to make sure the triangle shaped check valve isn't blocking fuel flow; it is a very common occurrence with our Mk4's.
_______________
Old November 28th, 2017, 08:56   #39
Owain@malonetuning
Glad to hear she's running! Landis is a solid dude, dropped off an 11mm the other day in an abarth race car
Once she's all done up I'm down to do a couple dyno runs, see how it compares to PP520s with similar mods.
Old November 28th, 2017, 11:02   #40
UhOh
UhOh's Avatar
As I'd figured (way back in post #8)!
Old November 28th, 2017, 16:03   #41
turbovan+tdi
turbovan+tdi's Avatar
Agreed, mmmmm BBQ, too bad we'll have to wait until next year when it stops raining and the sun comes out.
I use never seize on the body's to stop them seizing to the head.
Old December 3rd, 2017, 07:34   #42
munly
Wondering if someone could provide advice. After these modifications the car produces a large cloud of white smoke on cold startup. As well as the idle is irregular for a about 10-20 seconds. This happened occasionally before the mods, but now its consistently occurring. Other than the initial start up the car runs fine, the idle is stable once the car has warmed up. The first shop that installed my nozzles played with the IQ via Ross-tech, trying to get car to run properly. I believe it was set between 2-3.
My questions are:
Does the IQ "self adjust" to a certain extent?
Do these symptoms seem like an over fuelling issue?
Should I track down someone with Ross-tech and adjust the IQ again?
Thanks again.
Old December 3rd, 2017, 09:16   #43
PB_NB
PB_NB's Avatar
I have a similar smokey start up. but my smoke is more hazy and bluish white. It lasts about a minute and clears up and then after that I get only black puffs at WOT or when pulling the trailer. I know that the black smoke is related to excessive fuelling however, the DLC1019 nozzles are more on the lean side when it comes to aftermarket nozzles.
My IQ is set at 4.0.
I have a new new Rosstech Cable (KII-USB) if you would like, I could let you have if for a great price (PM me if you are interested and you can swing over and grab it). I bought another new one that covers the 07 GTI and Beetle so this one is extra now.
The cable would be very handy if you feel comfortable getting in and understanding your car.
Old December 12th, 2017, 11:37   #44
turbovan+tdi
My questions are:
Thanks again.
The IQ is not self learning.
White smoke is unburned fuel, so its either injector issues or compression.
2-3 isn't bad at all, but every car is different so it might need some fine tuning.
Old December 12th, 2017, 14:05   #45
wonneber
Retarded injection timing?
Did it...Malone Stage 2 tune Rayzer VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 84 July 16th, 2018 05:27
Malone tune stage 2 or 3 Nathaniel.Troy TDI Power Enhancements 42 July 9th, 2015 11:39
Malone stage 2 tune Barker1632 TDI Power Enhancements 10 July 6th, 2015 11:27
Malone tune stage 3 or 4 ? acer2525 VW MKIV-A4 TDIs (VE and PD) 9 January 4th, 2013 20:35
.216 or .232 with malone stage 3? TOPH R TDI Power Enhancements 18 February 25th, 2012 11:18
Page generated in 0.15388 seconds with 11 queries
[Output: 136.65 Kb. compressed to 114.93 Kb. by saving 21.72 Kb. (15.90%)]
