Old December 12th, 2017, 13:49   #31
wonneber
Originally Posted by dubStrom View Post
I do not know if it does this double pull thing when it is unlocked. I think I noticed that happening once or twice, but cannot remember.
I forgot to mention it's only from a locked door.
Once opened I can open and close the door from outside no problem.
Inside handle works 100%
Old June 30th, 2018, 17:38   #32
dubStrom
dubStrom's Avatar
Default Done with the right front suspension
Bilstein TC sport struts are on both sides now. I am waiting for a left wheel bearing housing from IDParts (PO stripped the lower caliper guide pin threads).
Meantime, I completed the right side
New CV joint/boot kit from IDParts, new lower ball joint, and replaced the Control arm bushings, The rear bushing is easy. But that front one is squirrly!
Feels good to have the right side done.
Lost my JSW to a reckless MB E350 sedan driver blowing a stoplight:
http://forums.tdiclub.com/showthread.php?t=472255
Working on a replacement project:
http://forums.tdiclub.com/showthread.php?t=472257
dubStrom is offline   Reply With Quote
Old July 1st, 2018, 06:45   #33
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Can't believe how rust free the underside of that car is!
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old July 8th, 2018, 07:59   #34
dubStrom
dubStrom's Avatar
Default Front End Surprises
Oh Boy...
I knew that the previous owner stripped the threads in the wheel bearing housing for one of the caliper guide pins, and I am not doing helicoil on that. New knuckle ready to assemble.
But when I tried to press out the hub, it split the wheel bearing inner race into two halves!! I can't get the thing off. New hub on the way, and the job waits:
Then I discovered that the inner CV boot is failed, with a typical sectional split in the crease. So I decided to get an inner CV AND boot kit so I don't end up doing this again next year!
But the LCA bushings are in and the LCA is mounted and ready to go. Oh, and I got an 8mm three square socket to do the inner CV kit. So maybe I can get this job done next weekend, and take it in for (another) alignment.
Somebody looking for a project fukeen Ontario 3 August 16th, 2016 06:37
My New Project odinsjetta VW MKIV-A4 TDIs (VE and PD) 20 November 1st, 2014 08:09
Wtt project for a project Yotaman87 Private TDI Items for Sale/Wanted 0 January 11th, 2014 16:57
help with new project Shauger TDI Conversions 6 September 30th, 2007 17:14
Page generated in 0.12727 seconds with 11 queries
[Output: 69.20 Kb. compressed to 62.18 Kb. by saving 7.02 Kb. (10.14%)]
