Old December 10th, 2016, 15:31   #1
V-DubLuv
Fuel Economy: low 50's stock mid 40's w/ mods
Default Overheating after thermostat install
Finally got around to swapping thermostats in my Jetta after dealing with slow warm up times and little heat in the cabin. Bought oem parts and went for it.
Pulled the coolant ball and pulled the thermostat and housing. Popped the new parts back in, they can only go in one way, topped off the engine with coolant and went for a drive.
After the drive I noticed there was more coolant in the ball than when I started. I took off the cap and there was a very heavy vacuum/ suction on the tank and the coolant was bubbling. After removing the cap, the coolant began draining out of the ball and it sounded like crackling from coolant going into a sizzling engine block. I've tried burping the cooling system but the lower radiator hose remains empty like there is no coolant getting passed the thermostat.
Is there anything I'm overlooking? Or did I get a bad thermostat that is stuck closed? I've seen thermostats fail "open" as they should, but nothing like I'm experiencing.
GTB1756vk w/ Malone stage 5
Neuspeed race springs w/ 28mm RSB
Leather interior swap, Custom sound system
TT front end swap w/ 312mm brakes
V-DubLuv is offline   Reply With Quote
Old December 10th, 2016, 16:24   #2
Vince Waldon
Vince Waldon's Avatar
The factory manual used to recommend testing new t-stats in boiling water before installation. Dunno if it still does, but I do.
Since that's all you've changed, I might be inclined to at least start there, if only to rule it out.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old December 10th, 2016, 18:47   #3
maxmoo
Could be the thermostat but it's rare....was it oem?
Or even more likely, IMO,..... these engines are prone to air lock..... are you sure you put as much coolant back in as you drained out?
maxmoo is offline   Reply With Quote
Old December 10th, 2016, 19:12   #4
V-DubLuv
It was an ID Parts kit. I didn't drain any coolant except for taking off the coolant ball and Didn't lose a Whole lot since I worked quickly. ( too much effort to drain radiator with a panzer plate and lowered car)
I've done a couple thermostat changes on my golf with no problems. How do I get rid of the air aside from regular burping?
Old December 11th, 2016, 08:14   #5
maxmoo
I use my oil extractor to vacuum most of the air out of the system by connecting it to the small hose at the expansion tank until I get coolant.
Old December 11th, 2016, 17:53   #6
2many diesels
If you pulled the thermostat you lost coolant. Betting you are not bled out have have air trapped in the system.
2many diesels is offline   Reply With Quote
Old December 11th, 2016, 21:27   #7
V-DubLuv
Lost about 1 1/2 cups of coolant. Had the new thermostat clipped into the housing ready to go as I pulled the old unit out, minimal spillage. I'll try to pull a vacuum on the return line in the morning. Thanks for the info
Old December 12th, 2016, 07:01   #8
pdq import repair
Fuel Economy: 38.5
I like to fill the engine through the upper hose till full. Too easy to get airlocks in todays cars, not just VW. Hope the overheat didn't cost you a headgsket.
pdq import repair is offline   Reply With Quote
Old December 12th, 2016, 17:22   #9
V-DubLuv
Used my mity vac on the return line for the coolant ball until I was able to get some coolant through the line. Started the car and drove around until it was up to running temp but I am not getting any coolant through the return line. Looks like there is no coolant circulating?
Old December 13th, 2016, 11:42   #10
wonneber
Drive it some more to see if it overheats.
Stay local just in case.
The dash gauge may say its up to temp but the dash gauge does not follow the ECU temp side of the temp sensor.
I've see it on mine in VAD.
With the cold weather the car may not produce enough heat at idle to open the thermostat.
Last thing if you do not see coolant returning in the small hose at the ball reserve the water pump impeller may not be turning.
Plastic impellers are known for this.
Was the water pump replaced recently.
I might have missed some of this.
Rich W.
Old December 13th, 2016, 12:09   #11
TwinTurboKen
I just did my thermostat last night. I let the block drain out of the thermostat hole replaced the tstat after it stopped draining, put the hose and housing back on and tightened down, rinsed the block with water and a funnel to clean off leaked coolant.
filled up the ball till it wouldn't drain down anymore and squeezed the upper hose and lower hose to help move coolant around and get bubbles out added more coolant as necessary.
then started up the car and used a stick against the seat and adjusted the seat recline forward to push the throttle to hold at 2k rpm and had heat on full blast until the car got to 190 on the gauge while monitoring return line flow and squeezing the hoses periodically.
Took the car on a 45 mile round trip drive last night and no issues. holds solid 190
You probably have air trapped. I would always leave the lid off the ball, and run the car hood open and throttle held down with a throttle stick or jerry rig something to hold down throttle to maintain around 1.8-2k RPM until the thermostat opens. If it doesn't open you have a problem and will know before it ever gets out to the road.
04 Jetta TDI 5-spd Malone S1 + dyn EGR/idle
00 Dodge Ram 2500 4x4 cummins 6-spd compounds, unicorn injectors, 53 block (576hp/1285tq 8/10/2013)
TwinTurboKen is offline   Reply With Quote
Old December 13th, 2016, 18:43   #12
V-DubLuv
Drove around with the lid off of the tank a couple times already. The water pump has a metal impeller on it but the car is about due for another timing belt. I am getting a foamy dribble on the return line at best, car doesn't seem to be over heating although it does smell "hot" if that makes sense.
Old December 13th, 2017, 10:07   #13
JB05
Fuel Economy: 43/41/40
I'm having a similar problem. I changed the t-stat a couple of weeks ago because my Ultra Gauge was reading 195F which is hotter than normal, and during the Summer it would reach 200F if I was stuck in traffic. There is good flow coming out the return circuit of the resevoir, but my lower radiator hose is always cold. Cabin heat is good; so I think I may have an air pocket or a clogged radiator.
I would like to know the OP's outcome.
JB05 is offline   Reply With Quote
Old December 13th, 2017, 11:12   #14
wonneber
The lower hose should be the colder coolant from the radiator going into the engine.
I wouldn't be worried about 200 F in the summer.
If you get 200 F now I would worry.
Old December 13th, 2017, 20:42   #15
UhOh
UhOh's Avatar
I think that there are differences in t-stats. Wife's car runs about 5 degrees warmer than mine: about 195 vs. 190. Never an issue.
ALH Overheating; replaced thermostat. Still overheating. DaveLinger TDI 101 24 February 13th, 2014 13:18
Overheating Again riebs VW MKIV-A4 TDIs (VE and PD) 11 September 20th, 2010 21:37
Thermostat? Overheating issue mk3_gurl Other VW Group TD(I)s 20 September 11th, 2007 12:21
Oil Cooler And Thermostat-sandwich Install... Satiro TDI Power Enhancements 18 February 21st, 2007 15:34
2001 Jetta TDI overheating. Thermostat or WP? bman328 VW MKIV-A4 TDIs (VE and PD) 14 February 18th, 2006 10:50
Page generated in 0.14882 seconds with 11 queries
[Output: 124.46 Kb. compressed to 103.86 Kb. by saving 20.59 Kb. (16.55%)]
