Old August 18th, 2016, 10:11   #31
Uisge
This saved me hours of work and hundreds of dollars! Thank you!
My 2002 Jetta, with 348000 km finally stopped charging. This thread helped me pull the old regulator off, and buy a replacement (knock-off) from my local garage for $75CAD. I could have bought one a lot cheaper online from Sofia, Bulgaria, but the delivery time was about three weeks.
The dealership quoted $512 for a new alternator, or $155 for a new regulator. At a local auto parts store, a remanufactured alternator was $284, and a regulator was $105.
I'm happy now.
**A note that Step 6 (remove 15mm nut) should come after Step 4.**
2002 Black Jetta GLS TDI 5-Spd Manual - 350,000km
*2005 Silver smart fortwo Passion Cabrio cdi - Written off *
Uisge is offline   Reply With Quote
Old December 13th, 2017, 15:28   #32
zukikat
Fuel Economy: 45mpg hwy
Valeo vs Bosch
So my 2003 TDI Jetta wagon has a Valeo alternator which just started making the battery light illuminate on my instrument cluster and 11.5 volts show on my scangauge instead of more like 13.9 volts.
The disassembly process to access the regulator on my 2003 ALH TDI Jetta wagon's Valeo alternator is similar to the Bosch but not exactly the same.
I'll double-check the Valeo nut sizes and update this post when I go to reassemble things.
On my Valeo alternator
I carefully removed the plastic cap from the big main B+ wire's nut with a flathead screwdriver,
I removed that wire's retainer nut from the B+ stud, 13mm I believe,
I removed that wire's retainer clamp nut from an alternator housing stud at the opposite corner from the B+ wire's stud,
I lifted the locking tab and unplugged the 2-wire connector off the regulator,
I removed the two 7mm cover retainer nuts with a deep socket and the cover easily slid off.
At that point there are just 3 small bolts holding the regulator to the alternator housing and a plastic brush assembly cover/cap attached to the regulator.
The Valeo regulator is completely different from the Bosch versions, I don't see any part numbers on the regulator itself, and a google search isn't helping so at the moment I don't know what a good replacement regulator part number for my 120A Valeo alternator is and the ones I am finding are all far more expensive than the Bosch ones.
My primary reason for adding this post to this thread is to let others know that there is more than one brand of alternator available for these vehicles and different types of regulators that are not all interchangagle depending on the brand so you need to look at what alternator you have before buying any parts.
zukikat is offline   Reply With Quote
Alternator, Replace voltage regulator or rebuild/buy rebuilt alternator? TDI Jim VW MKIII-A3/B4 TDIs 2 February 19th, 2008 16:37
where can I purchase brushes for alternator ? vwtdi04 Ontario 8 June 1st, 2007 19:08
Alternator? Regulator? almus VW MKIV-A4 TDIs (VE and PD) 8 October 3rd, 2006 17:38
replace voltage regulator and brushes? bjapundza TDI 101 3 October 26th, 2005 12:24
A-3 Alternator / V. Regulator Herm TDI VW MKIII-A3/B4 TDIs 3 May 4th, 2004 19:55
Page generated in 0.14883 seconds with 11 queries
[Output: 55.46 Kb. compressed to 51.27 Kb. by saving 4.20 Kb. (7.57%)]
