MK3 & B4 Short Shift Kits
k_harley
Vendor , w/Business number
Lowell, MA
2006 Jetta TDI, 2005 Audi S4, 1997 Audi A4 Race car, 2004 Passat TDI 6MT 4motion
Ya, this only fits the MK3 and B4, which really dont have any other parts available for them. The later models do have parts available already.
Hollyfeld
Northern New Jersey
2005 Jetta MKIV
Thanks for the reply. I noticed in this thread that you mentioned you might be working on prototypes for the MK4, or at least that’s how I interpreted it. The kits on dieselgeeks.com are close to $200 and Im not about to spend that much loot on a short-shift kit. :(
k_harley
Lowell, MA
Sorry, I only have the kit for 02A's.
CharlieT
Houston, Tx
Audi TTqTDI, B4V, B5.5V, '12 NMS SEL
Finally got a spare minute, so installed mine today. Easy 10 min job.
It works GREAT, elegantly simple.
I found the shift a little stiff at first, so I removed the allen head bolt again and lightly greased around the shaft, washer and head, that made a big difference.
Feels great now, thanks !!
Just checking back in. 6 months, 8000 miles and a lot of 'quick' shifts later, still working great. Thanks !!
NextExit
Townsend, Mass.
2014 Sportwagen
... Gruven parts makes a stainless steel piece that replaces that plasctic relay lever and reduces the throw, but Ive tried it and I personally think it takes too much leverage away from the side to side motion of the shifter and makes it difficult to find the gear.
I don't have that particular complaint with the Gruvenparts transfer lever. For me, having it seize up in the shift tower's bore was no fun and I still haven't solved the problem that it relocates its shift cable so low that the two cable boots rub when I push into 5th. Even if I do solve this it's too late for the boots. They wore holes in each other before I got one wrapped in Teflon tape and greased with silicone grease.
k_harley
Lowell, MA
Good to get some longer term feedback, that's more miles than I've put on mine.
"For me, having it seize up in the shift tower's bore was no fun"
Hah, it took not only a 2 lb. sledge hammer, but a vice aiding that force at the same time.
kbarnett
Seacoast NH
2001 Jetta TDI, 2002 Jetta TDI, 1985 Big Turbo ALH TDI Project
Money sent. Cant wait to get it installed. Thanks
k_harley
Lowell, MA
Roger that, are you aware that this is for an MK3 or B4? I noticed the beetle in your sig, wont work on that one.
Drag SGT
Oregon
98 Jetta TDI
Money sent! I'm excited to see how much it changes the feel. It's a bummer the side/side part from Gruven doesn't work all that well; I'd love to use the two in conjunction.
myke_w
Cbus, Ohio
03 TDI Wagon
k_harley, can you confirm this is designed to replace all hardware on the shift cable that has the goofy vertical mounting bolt? My setup is wiped out and I'd hate to put it back to stock when the guy 60 miles down the road is selling the perfected version.
k_harley
Lowell, MA
Yes, Im pretty sure from what I understand you are asking....
This replaces the
-Shift weight
-13mm head bolt that holds down shift weight
-13mm head bolt that secures fore-aft shift cable
As long as your shift tower is intact, this should be a go
I only have 3 left from my original production run.
myke_w
Cbus, Ohio
03 TDI Wagon
In reference to this schematic..
I'd like to make sure that 36, 45, 46, 47 and 52 are no longer needed.
k_harley
Lowell, MA
Correct, nothing listed above is re-used.
bigsexyTDI
Kentucky
'98 NB, '04 Jetta
Any word on the '98 Beetle fitment yet? Wasnt the DG piece able to work on it? Really want this...
k_harley
Lowell, MA
Im going to make up a few more today as there are a number of people asking / waiting for them. I will confirm once they are ready to ship.
k_harley
Lowell, MA
These are back in stock and ready to ship
SD26
WI
1998 Jetta TDI 5sp, 2002 Jetta TDI 5sp
Got mine Saturday!
Installed! Loving it! My son uses this car (A3 Jetta) the most, and even he recognized the difference. Great little upgrade!
k_harley
Lowell, MA
OK, well I blew through the batch I just made with the material I had left on hand. I need to go re-stock and make more.
No, this does not replace much of the linkage. It just takes the place of the securing hardware for the fore-aft cable.
Yes, gruvenparts does make that stainless piece for the side to side portion, its a nicely crafted piece, but in my opinion, it takes away too much of the leverage needed for that shifter action.
There are a couple of other pieces that are wear items that are a good idea to replace if the ole shifter is starting to feel a little sloppy.
TDI Jim
Gaithersburg, Maryland
1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat
I could use a B4 short shifter, are they still available?
k_harley
Lowell, MA
I think I have one left on the shelf. I probably wont be making another batch for a few weeks because I have to go fetch some more material for the next round.
Let me know if you want it.
TDI Jim
Yes, I will take it Keith. I also called and left a message and email.
nicklockard
Torque Dorque
Arizona
SOLD 2010 Touareg Tdi w/factory Tow PCKG
moderator bump for page reset to push locked threads off front page.
