Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old December 10th, 2017, 14:39   #46
crawdaddy
crawdaddy's Avatar
Originally Posted by kirky00 View Post
Completely getting out of WV's for a while, parting out my 2001 golf TDI 5 speed and all the parts i've collected over the years. Willing to ship on at buyers expense, or meet me in Sudbury on December 15th, can bring anything up with me then. all parts located in Cochrane Ontario.
-PP520 injectors balanced and pop tested $300 PENDING SALE
- Stock 5 speed injectors 330K $20
- 2 x 11mm pump $300 each
- 10mm pump 300 K needs top cover seals $100
-10mm pump CORE only FREE!
- 3 bar map sensor $20 - SOLD
-Intercooler with factory map sensor $30
- Upper and lower charge pipes $40 for the pair
- VNT 15 turbo 250K on it, no shaft play $100
- ARP head studs $80 SOLD
Kerma VNT 17 adapter $20 comes with the lower charge pipe already cut to fit.
-Intake manifold, clean and comes with EGR delete pipe $50
-2x intake manifolds that need to be cleaned $20 each
- Southbend stage 2 daily clutch/flywheel 100k $400
- 5 speed manual trans, no grinds and shifts great $250 or $350 for a complete auto to manual swap with out clutch or $700 with a south bend stage 2 daily w.flywheel
-ALH engine running but has a misfire, has 300 KMís, new timing belt kit $200
ALH complete engine with 500 KMís, block and pistons are in great shape, needed head gasket and timing belt service when pulled, comes with accessory bracket and PS pump $100
ALH complete engine, 300 KMís, had a broken timing belt when pulled, 3 lifters and the cam were damaged, other then that its in good shape $100
- 5 speed manual trans 370KMís on it, Needs and shift tower for sure $40
-2 wire glow plug harness bran new never used $40
-ABS pump $20
-Rear axle wheel bearing stub NEW $20
-Rear drivers side dust shield NEW $5
-Glove box, big style in mint shape $20
- Good year Nordic winter studded tires on factory Volkswagen rims 205/65R15 $400 Also have black steel rims in 5x114.3 and 5x112 that i can have these tires mounted on.
- Volkswagen rims 15í with some bald general tires 195/65R15 $80
- Frost heater for a manual ALH $60
- Cloth interior FREE
-Kerma VR6 springs 200KMís on them front ones come with KYB gas shocks $80
- Sub frame with lower control arms, audi TT bushings and new greaseable ball joints, can come with steering rack with tie rods as well $80
I'm interested in some parts. I emailed you, please check your email and reply ASAP. Thank you
crawdaddy is offline   Reply With Quote
Page generated in 0.11464 seconds with 12 queries
[Output: 48.34 Kb. compressed to 45.60 Kb. by saving 2.74 Kb. (5.67%)]
