Old November 21st, 2017, 19:05   #16
lexi.kiselev
UPDATE:
i finally got the new MAP flange welded.
When I run a boost leak test on the intercooler piping i do not have any pressure drop. Once i run the boost test with pipes connected to the intake manifold the pressure drops.
Is that due to an open exhaust valve?
i just recorded 2 log, I am still getting overboost
http://log.malonetuning.com/chart/35...gsKWwo0AAAA%3D
lexi.kiselev is offline   Reply With Quote
Old November 21st, 2017, 20:37   #17
Owain@malonetuning
Careful with that much overboost at that high of RPM, turbo is spinning very fast. Can cut fueling a bunch if you'd like but that can only do so much.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old December 3rd, 2017, 18:20   #18
lexi.kiselev
Got some updates
i havnt touched the overboost issue since but i have started taking the runner apart.
i am going to redo the whole front suspension in order to lower the Runner.
With the leaf springs i can not lower it because the pitman arm will hit the leaf spring. So i will be reusing the factor fj80 Land Cruiser suspension.
parts that i have so far:
fj80 land cruiser axle with factory locker
ballistic fab adjustable coil bucker
radius arms / panhard bar / sway bar
frame stiffener plates
coils
ive started taring apart the leaf suspension this weekend
i got the frame all cleaned up, its fready for the frame reinforcment to be welded on
Untitled by lex kiselev, on Flickr
Old December 4th, 2017, 10:40   #19
smelly621
What's the difference in track width with the FJ80 axle? Do you have plans for a matching rear FJ80 axle?
smelly621 is offline   Reply With Quote
Old December 4th, 2017, 21:44   #20
lexi.kiselev
The fj80 will be 2.3" wider than what i have right now (mini axle w/ IFS hubs and 1.25" spacers). I was thinking about matching the rear but not anytime soon. The rear axle is offset by 3.5" to the passenger side right where my gas tank is. I would have to modify the tank to clear the driveshaft
Old December 5th, 2017, 10:51   #21
KBCB
KBCB's Avatar
TDI(s): none
I'll be watching to see how this goes, as I might to have to consider something similar. I installed cross-over steering on my 4R and because I don't have much lift on mine I had to make my own, nearly flat, pitman arm and I have concerns that the linkage is going to contact the pan significantly.
1985 Toyota 4Runner. Soon to be TDi powered.
2001 Dodge Ram 2500 Cummins 5.9l
2004 Toyota Tacoma 3.4l
KBCB is offline   Reply With Quote
Old December 6th, 2017, 00:01   #22
lexi.kiselev
KBCB, did you push your engine and axle forward by any chance?
I got the reinforcement plates all burned in.
Finally got the axle under the truck for mock up, so far its looking good.
Old December 6th, 2017, 10:34   #23
smelly621
That axle looks beastly under there, but what's really catching my eye is those jackstands. They are pretty hardcore looking!
Old December 7th, 2017, 00:54   #24
lexi.kiselev
haha Yeah i know, they look russian ghetto fab. My brother built for one of his projects. I need to invest in some proper stands
Old December 7th, 2017, 12:02   #25
KBCB
KBCB's Avatar
TDI(s): none
No, I had considered moving it forward but decided against it. Don't remember why.
Old December 7th, 2017, 20:43   #26
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Are you going to coil spring it or go leafs?
1.9ZOOK is offline   Reply With Quote
Old December 8th, 2017, 00:06   #27
lexi.kiselev
Im installing coil springs. The front suspension is from a fj80 land cruiser
Old December 8th, 2017, 08:58   #28
KBCB
KBCB's Avatar
TDI(s): none
I'm curious, why did you decide to go with an 80 axle, instead of adding coils to the axle that you already had?
Inquiring minds...
Old December 8th, 2017, 10:10   #29
lexi.kiselev
There are a few reasons why i chose the 80.
The mini axle isnt wide enough for coils springs, i could have used coil-overs but thats out of my budget
I wanted to retain the factory arms and suspension to keep the cost down
The 80 is wider, so i wouldnt need to run any spacers and ifs hubs ( more stress on trunion bearings)
the birfields are bigger and stronger... nothing compared to longfields, but those are also $$
Last but not least, a high pinion 3rd w/ ELOCKER
Old December 9th, 2017, 08:55   #30
KBCB
KBCB's Avatar
TDI(s): none
So.... YES... got it!
TDI 4Runner tdi4runner TDI Conversions 28 November 13th, 2016 21:04
IQ is way off after sitting 1.81, 1.88, -1.86, -1.88 DougInFL VW MKIV-A4 TDIs (VE and PD) 25 July 21st, 2015 15:53
88 4runner - ALH Danielg42 TDI Conversions 140 February 27th, 2013 11:59
RBX 88 4Runner Diesel Swap RBX TDI Conversions 32 April 25th, 2011 05:00
TDI into 4Runner? RoundHouse TDI Conversions 19 July 21st, 2006 18:14
Page generated in 0.14157 seconds with 12 queries
[Output: 121.98 Kb. compressed to 101.46 Kb. by saving 20.52 Kb. (16.82%)]
