Old September 30th, 2004, 19:33   #1
nathankaufman23
TDI(s): N/A
Default Turbo Timers
~Deleted~
nathankaufman23 is offline   Reply With Quote
Old October 1st, 2004, 09:10   #2
Darren_J
TDI(s): MK 4 TDI
Not rquired unless you are extremely A/R. Best thing for turbo longetivity is to keep it out of surge. The turbo cools down quickly at idle due to low EGT. A minute or 2 is enough, plus the synthetic oil has a higher coking point then conventional oil.
Darren_J is offline   Reply With Quote
Old October 1st, 2004, 12:49   #3
Rammstein
TDI(s): Golf 92 D
Fuel Economy: 4.31/5.05/6.16
A turbo's best friend is a pyrometer.
You can see and know for sure that it's safe to turn everything off.
I believe every turbo engine should come with one and a boost gauge.
Really basic stuff you know.
Rammstein is offline   Reply With Quote
Old October 1st, 2004, 13:54   #4
03_01_TDI
Banned
TDI(s): Na
the larger heat exchanger from the passat TDI is a good idea.
03_01_TDI is offline   Reply With Quote
© 1996 - 2020, All Rights Reserved
Page generated in 0.13584 seconds with 10 queries
[Output: 57.28 Kb. compressed to 50.83 Kb. by saving 6.45 Kb. (11.27%)]
