Old October 8th, 2015, 08:17   #1
MaroonB4
MaroonB4's Avatar
Fuel Economy: 40ish, and I ain't easy on the go pedal
Default replacing motor mounts on 09 Jetta
Is this something I can take on at home? I have found an 09 with 139k on the clock that the owner is asking $4950 for. He claims it just needs new motor mounts, I have not been able to look at it yet. I haven't owned/worked on one newer than the MK4 ALH, so this would be a new animal for me. I am always looking for good TDI flips, and from pricing the motor mounts and the car it looks like I should be able to make a couple bucks if I can do the work in my garage.
Thanks!
MaroonB4 is offline   Reply With Quote
Old October 8th, 2015, 09:52   #2
C3156
TDI(s): All sold
Fuel Economy: With or w/o emmisions?
As long as you have a floor jack and jack stands, it should not be an issue.
Based on mileage, I would be interested in if the HPFP had been replaced or not.
Former owner of 2009 & 2010 TDI's
C3156 is offline   Reply With Quote
Old October 8th, 2015, 11:40   #3
Carlos_TJ
.....and DPF levels, that would require a replacement soon....
Carlos_TJ is offline   Reply With Quote
Old October 8th, 2015, 11:56   #4
MaroonB4
MaroonB4's Avatar
Is the HPFP a wear item, or does it just take a dump at random intervals? never mind, will just use the 'search' function before i am flamed unnecessarily like some newbie...LOL
Thanks for the input guys...i never even thought about the DPF
Old October 8th, 2015, 17:57   #5
meerschm
meerschm's Avatar
good idea to check into the DPF, but there is no reason to think it would be a problem at only 140k. some folks have put more like 250k on them before the ash loaded up.
on the other hand, some DPFs crack.
do you have a VCDS to scan it with?
check the tailpipe for soot.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old October 9th, 2015, 13:56   #6
South Coast Guy
Fuel Economy: Good
Thanks!
I would be a little suspicious; why would a car with that few miles need new motor mounts? I don't think I have ever seen a posting about failed mounts on '09 diesels.
South Coast Guy is offline   Reply With Quote
TDI 09 Jetta front right motor mounts Sparkie4rival VW MKV-A5 Golf/Jettas 0 December 31st, 2013 04:37
Replacing motor mounts Revolutionary_mind TDI 101 7 November 26th, 2008 09:24
Tips & Tricks on replacing motor mounts on a 98 Jetta latitude500 VW MKIII-A3/B4 TDIs 1 November 6th, 2006 06:15
motor mounts: replacing gboss VW MKIII-A3/B4 TDIs 8 October 22nd, 2003 12:53
'98 Jetta Motor mounts brian VW MKIII-A3/B4 TDIs 17 February 28th, 2003 00:17
© 1996 - 2020, All Rights Reserved
Page generated in 0.13881 seconds with 11 queries
[Output: 74.80 Kb. compressed to 65.59 Kb. by saving 9.20 Kb. (12.31%)]
