Old February 10th, 2015, 01:22   #31
ARO
ARO's Avatar
Fuel Economy: 44-51
Originally Posted by GLHTurbo View Post
I just installed a Westfalia hitch on my 05 MK4 Sedan.
I couldn't bring myself to pay for the connectors to plug into the tail light bulb holders for a splice-free installation.
VW wants $18 alone just for the 1 pin connector! Part 191972701
I bought a MK3 Jetta trunk light harness for $22 shipped from eBay. It has 3 of the 3-pin connectors, 2 of the 1-pin connectors, and several 2-pin connectors that won't be needed (but I think they might be useful for a Passat owner). And it has the pins/wiring already so I didn't need to buy any of those repair kits that come with the yellow wire with the pin on the end.
Hope this helps someone else save a few bucks!
Is this the harness on ebay???
http://www.ebay.com/itm/Trunk-Wiring...0224a5&vxp=mtr
I only need the connectors, so I can do the electrical for trailer hitch, on my MK4 Jetta. Thanks
79 Mercedes 240 Diesel MT-sold in 2006
01 Jetta/Bora TDI MT-sold in 2016
07 Volvo VNL 780 TD 13 spd. auto
ARO is offline   Reply With Quote
Old February 10th, 2015, 07:53   #32
romad
romad's Avatar
Aro, have you checked out the recycling yards in Sacramento? The Pick-N-Pull has MK3 Jettas as do the Rancho Cordova, Rocklin and Stockton locations.
The fleet:
romad is online now   Reply With Quote
Old February 10th, 2015, 09:04   #33
ARO
ARO's Avatar
Fuel Economy: 44-51
Romad, I will defiantly check next time I go to Rancho Cordova. There are a few VW specific junkyards there....
I just figured it's easier to just buy it off ebay.
Old February 10th, 2015, 09:32   #34
romad
romad's Avatar
Where in Sacto are you? The Stockton Blvd (7600 Stockton Blvd
Sacramento, CA 9582) Pick-N-Pull has several MK3 Jettas.
The fleet:
Old February 10th, 2015, 10:04   #35
ARO
ARO's Avatar
Fuel Economy: 44-51
Thanks. I live between downtown Sac and the SMF airport. But I am trucking thru Arizona now. I'll go to Pick-N-Pull when I get back home in a few days....
Old February 10th, 2015, 10:20   #36
romad
romad's Avatar
North Natomas? My sister lives there. I just checked for an AZ location but there are none. Here is the website if you want to check for locations near your route: http://www.picknpull.com/locations.aspx
The fleet:
Old February 11th, 2015, 10:55   #37
ARO
ARO's Avatar
Fuel Economy: 44-51
Yes, that's right, North Natomas!
It is quite hard for me to park a semi truck at the junkyards along the way so, I'll just go to Rancho Cordova when I get back home, I am sure I'll find what I need, there are plenty VW junkyards there.
Old March 25th, 2015, 14:26   #38
SFHGolfTDI
SFHGolfTDI's Avatar
Herm and Romad, and others who have done this. Where are folks locating the converter box? Spare tire well? Driver side by amp? It seems it would also make sense to put it on the right/passenger side since it is close to the power port? Also, any links to quality cig lighter socket plugs that you have used?
Front end swap (Jolf), GTI tails, heated GTI leathers, GLI steering wheel, aluminum trim, center console w/cupholders, homelink visor, SGII, front/rear fogs, remote windows, 35% ceramic tint, Q5/Touareg rear wiper, roof rack, vented, PD engine cover mounts, Fumoto F106SW, panzer skid, Bilstein HDs, mudflaps, Conti PureContacts, custom 2" class II hitch. Kerma tuning. VCDS available (K-II USB).
SFHGolfTDI is offline   Reply With Quote
Old March 25th, 2015, 15:00   #39
romad
romad's Avatar
Mine is on the LEFT side in the foam shelf where the CD changer would go. I open the cover, pull out the power plug and plug it into the power port then I close the cover.
The fleet:
Old March 25th, 2015, 15:02   #40
SFHGolfTDI
SFHGolfTDI's Avatar
So you pull the power cord all the way to the other side of the trunk? In my Golf, the outlet is on the passenger side by the trunk light. Is that similar for the wagon?
Old March 25th, 2015, 15:12   #41
romad
romad's Avatar
No, in the wagon, the power outlet is on the left (driver's) side. Thus all my connections (except for right turn signal) are to the left taillight assembly. You could use the right taillight assembly (except for the left turn signal) for the connections. Is there a storage cubby on the right side of your Golf? My wagon has one there.
See the last 5 pictures here: http://forums.tdiclub.com/showpost.p...&postcount=335
The fleet:
Old March 25th, 2015, 15:18   #42
SFHGolfTDI
SFHGolfTDI's Avatar
Interesting. That is a difference between the two models. There is an access hole for the passenger side light, but the "cubby" is still on the driver side, along with the amp and where the cd changer would fit. I'll have to have a look at it and see where it would be best located for the cleanest wiring setup.
Old March 27th, 2015, 07:35   #43
romad
romad's Avatar
My wagon has a cubby on the right side also; it is where the first aid kit (mandatory in Germany) is to be stored and is marked with the green cross on white disc. I use it for my fuel additive storage. Oh, the left side cubby is marked with the red triangle on white disc symbol for the warning triangle (again, mandatory in Germany); the warning triangle I brought back from my last tour in Germany (1984-88) is too big to fit!
The fleet:
Old May 5th, 2015, 16:06   #44
SFHGolfTDI
SFHGolfTDI's Avatar
I just found a "cheaper" Curt powered adapter:
Curt 56187 3 to 2 Wire Power Converter
From the description at the Curt website, this one handles 7.5 watts/ circuit while the other model only handles 6 watts. I've asked Curt for more info.
Romad, which power converter did you end up using? I'm hoping to get a custom hitch installed soon (using euro hitch mount through frame rail, but will be 2" receiver) and need to build my harness.
Old May 6th, 2015, 07:14   #45
romad
romad's Avatar
I ended up using this one: Curt 56146 SMD Trailer Wire Converter It is now about $7.50 cheaper than when I bought it in March 2013 and is now cheaper than the other one. Oh, the reason I went with the 56146 is in post#14 above.
The fleet:
Trailer lights coolmg VW MKV-A5 Golf/Jettas 11 December 31st, 2011 05:13
trailer lights coolmg VW MKV-A5 Golf/Jettas 0 August 28th, 2011 04:57
Wiring for trailer lights - Need some help Charliebrown38 South Eastern USA 1 April 7th, 2005 13:38
Trailer lights for a New Beetle Mike Morriss Upgrades (non TDI Engine related) 2 December 6th, 2004 08:18
Trailer lights for a New Beetle Mike Morriss VW MKIV-A4 TDIs (VE and PD) 0 November 16th, 2004 08:57
Page generated in 0.17216 seconds with 11 queries
[Output: 142.96 Kb. compressed to 120.42 Kb. by saving 22.54 Kb. (15.77%)]
