Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > South Eastern USA
South Eastern USA Local discussions for those in the South Eastern USA. (Alabama, Florida, Kentucky, Georgia, Mississippi, North Carolina, South Carolina, Tennessee)
Old April 19th, 2012, 06:21   #1
zortmo
TDI(s): 99, 01, 06
Default Appalachian Diesel Works - Asheville, NC
I would like to recommend Daniel Grindstaff near Asheville, NC. He has worked on two of the TDI's in our family. Daniel replaced my wife's 06 DSG flywheel. On my son's 03, the timing belt broke and caused damage to the valves but fortunately no cylinder wall damage. Daniel did a rebuild on this engine and it runs great. My son lives in Asheville near ADW shop.
I was a line mechanic at an Atlanta Porsche/Audi dealership when I was younger. At almost 60 I now try to avoid major work in my garage shop. I drive three hours to ADW for major repairs. Daniel is passionate about TDI's and IMO, a trustworthy and skilled mechanic.
Mike Asher
zortmo is offline   Reply With Quote
Old April 25th, 2012, 10:20   #2
laundryeater
laundryeater's Avatar
I'd like to second that. The Grindstaffs have changed out a timing belt and a head gasket for me now. No issues.
2000 Indigo Blue Golf GLS TDI :: 260,000 miles and counting :: RC4, VNT-17, Bosch .216s, VR6/G60 Clutch+Flywheel, 2.5" DP to 3" Pipe, PD Lift Pump, VR6 Raxles, Mullet Suspension (SDs in front, HDs in back), Ventectomy, Snowectomy, DG Racepipe, FrostHeater, McNally Boost/Pyro Gauge
2015 Silk Blue Metallic Golf Sportwagen S TDI
laundryeater is offline   Reply With Quote
Old April 25th, 2012, 15:22   #3
FLYTDI
Fuel Economy: 45-48 w/mixed driving
X3 for ADW
FLYTDI is offline   Reply With Quote
Old April 25th, 2012, 19:12   #4
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
Daniel does great work, I would highly recomend using them. Lots of knowledge there with Daniel and Landon, quality people.
2K jetta gl tdi 5spd 407k, RC5+, 17/22, R520's, ported head, Colt stg 2, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old April 26th, 2012, 20:57   #5
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
Great shop if you're close to the area. Highly recommended for both modified and OEM setups
I submitted them to be included on the "Trusted TDI Mechanics" list (Landon is on there already but not ADW):
http://forums.tdiclub.com/showpost.p...postcount=1958
https://docs.google.com/document/d/1.../edit?hl=en_US
02 Jetta, 17:1 CR 81mm ASV, Colt cam, Peloquin LSD, Raxles, FueLab pump, 12mm/DE143, Gibonta 5 x 0.018, NX nitrous, 6+6 turbo, Bilstein coilovers
MKVII GTI 6MT, full build, 525hp
MKVII GLI DQ381, 93 tune only, daily driver
loudspl is offline   Reply With Quote
Old April 27th, 2012, 05:41   #6
DanG144
I always highly recommend ADW to folks around here.
Old April 27th, 2012, 08:32   #7
ncroadwarrior
ncroadwarrior's Avatar
TDI(s): 04 JSW bew
bump for same here
04 jetta wagon, BEW, 09A
RC2, F06 Stg 2 cam,17 turbo, E-codes, Koni's, TT LCA's,
Skid Plate, tint, cat/vent/muffler/intake B'fly'd..frostheater..cat 2micron FF.
ncroadwarrior is offline   Reply With Quote
Old April 27th, 2012, 09:02   #8
d2305
The don't want my business. Never called me back, and didn't know how much they charged for a timing belt replacement.
d2305 is offline   Reply With Quote
Old April 27th, 2012, 09:05   #9
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Did Daniel take over for Landon? Or both still wrenching on TDIs?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old April 27th, 2012, 09:09   #10
Ski in NC
Fuel Economy: 48-52 typical
Small shops can get overwhelmed by work, calls and emails. Also, some projects blossom in scope and screw up all others on the schedule. Sometimes not every request gets a response. Nature of the business. And the folks try to have a life outside of work, too.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old April 27th, 2012, 15:50   #11
paramedick
paramedick's Avatar
I'm sure that was a aberration. Perhaps when Daniel took over for Landon? Please give them another chance.
I can highly recommend ADW. I've wrenched with both mechanics and they are very competent!
ps Landon still pitches in when needed
Old April 27th, 2012, 21:54   #12
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
Landon helps out on occasion but it's really Daniel's "proprietorship"
If you can't get a hold of him the first time keep trying. It's worth it. Honest work at reasonable rates. You can't go wrong with them
Old April 28th, 2012, 08:32   #13
d2305
I watched the video and have all the tools. I may give it a shot or find someone local.
Old April 29th, 2012, 09:48   #14
d2305
All is well the tdi land. Got a follow up e-mail from ADW.
Old May 2nd, 2012, 21:40   #15
fabed23
agreed with the above posts...
it may be hard to get thru to them but they are some good, honest, hardworking, and smart mechanics from what i have heard and experienced.
i had them change my TB and did a great job... FAST TOO!
took less than a half day and he was calling me back saying its done!
fabed23 is offline   Reply With Quote
Raleigh to Asheville, NC Jetta18T Road Trips 4 September 13th, 2010 21:39
Things to do in Asheville, NC Vegged-Out South Eastern USA 3 August 14th, 2008 06:19
Mechanic/Parts in Asheville NC? heartofgravy South Eastern USA 6 April 12th, 2007 13:01
BioDiesel in Asheville, NC TurbineWhine Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 16 October 22nd, 2006 19:54
More biodiesel near Asheville, NC Kaderabek South Eastern USA 6 September 15th, 2006 03:31
Page generated in 0.18245 seconds with 11 queries
[Output: 128.79 Kb. compressed to 107.33 Kb. by saving 21.46 Kb. (16.66%)]
