Old December 23rd, 2011, 18:14   #1
WillR
Default Replacing RS strut. Removing PS strut.
I figured I would post this with a simple title so maybe someone might find it searching for it.
I read everything I could find on how to replace the RS strut. This reading provided me with the information that the RS axle will hit on the sub frame, which prevents the hub from dropping far enough to get the strut out of the arm.
Popular Suggestions include:
1) using Spring compressors to shorten the shock.
2) Lowering the sub frame.
I tried #1. No way was that dam thing coming out. I really don't want to drop the sub frame: snap that bolt off and your in for a world of hurt.
So I sat back and looked at it and thought "Since you are also installing complete lower control arms, why not pull the lower arm and see if it the strut comes out"?
Problem solved. In fact I put the new strut back in, TC's with VR6 springs, 1 spacer and new mount without using the spring compressors.
Just move the rotor/hub forward which allows the axle to clear the sub frame (as you turn it CCW) and everything comes right apart.
Keep something handy (within reach) to hold up the rotor/hub, it's going to drop far enough to mess up your brake hose if you let it drop.
So if your thinking of doing struts, you probably need at least the rear lower control arm bushing anyway, so just do them all the same time, and pull the lower control arm first when you do the RS.
PS: I went with complete lower arms with ball joints because rock auto had them for like $36.00. I feel this was cheaper then rebuilding my old ones when you include the time to replace the bushings and ball joint.
Have fun!
WillR is offline   Reply With Quote
Old January 29th, 2012, 18:34   #2
BlackJet01
BlackJet01's Avatar
TDI(s): 01 Jetta
Thumbs up Nice post!
I searched while doing my struts today and came across your post.
Rear was a piece of cake, and drivers side wasn't bad either even though
I was still using original springs.
Passenger side I dropped the two 22mm bolts holding subframe together.
Wasn't bad at all, and allowed plenty of room to get strut out!
Car rides so much better now!!
2001 Black Jetta GLS TDI, 5 speed. Previous owner sold to buy 02 Volvo
BlackJet01 is offline   Reply With Quote
Old January 29th, 2012, 19:14   #3
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Just pull the axle. It's really easy.
runonbeer is offline   Reply With Quote
Old January 29th, 2012, 19:21   #4
BlackJet01
BlackJet01's Avatar
TDI(s): 01 Jetta
I think using the air ratchet on 2 very easy to reach bolts is much easier.
Old January 30th, 2012, 06:17   #5
WillR
I was just pointing out that removing the lower control arm allows you to remove the Passenger Side strut without using a spring compressor, removing the axle, or lowering the sub frame.
besides, the lower control arm bushings probably need to be replaced anyway .
Old January 30th, 2012, 06:44   #6
runonbeer
Pulling the axle has no affect on alignment. But I agree, pulling the subframe is also easy. But I do recommend an alignment check afterwards.
Old January 30th, 2012, 07:36   #7
BlackJet01
BlackJet01's Avatar
TDI(s): 01 Jetta
Thumbs up
Bottom line we all got the job done!
Old January 30th, 2012, 08:00   #8
WillR
Anytime you change the strut, top bushing, or spring you are in affect changing the ride height.
As you raise the front end, the toe will change and the tires will become toed out.
Picture the mount location of the outer tie rod drops but the stearing rack stays the same. In order to keep the tire (toe) pointing the same, you will need to make the tie rods longer.
Old January 30th, 2012, 13:40   #9
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
I am guessing that when you tried compressing the springs you you didn't have a nut welded on the other side of the compressors. That is about the only way this will work. Otherwise as you shorten the spring the threaded rods will take the place for where the spring was and you are still up a creek.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old January 30th, 2012, 13:56   #10
WillR
My single compresses tools can be changed so the thread is either on the top or bottom. Then once out of the car I put the big compressor on it that covers both sides of spring.
Not doubting your method, just saying:
"If this is the first time you have done your struts, you probably need control arm bushings", so just pull the control arm and the strut comes right out.
Old January 30th, 2012, 19:15   #11
ECUshockguy
TDI(s): 2004 Jetta
Video of how my mechanic did it. He did the control arm/axle method.
http://www.youtube.com/watch?v=Ux5TbjwJ9_c
ECUshockguy is offline   Reply With Quote
Old January 31st, 2012, 07:49   #12
WillR
Ok, that's another way. But watching the video I cringed when he knocked the strut out of the spindle. I bet he sells a lot of brake hoses
WTB: metalnerd strut nut tool and strut spreader bit myselfnjit Private TDI Items for Sale/Wanted 2 May 3rd, 2011 17:56
Replacing front strut mount bearing luceberg VW MKIII-A3/B4 TDIs 2 September 8th, 2010 02:45
seeking strut compression tool & strut spreader bit (Denver, CO) emergencee Upgrades (non TDI Engine related) 13 October 26th, 2009 10:37
Replacing front strut - can any shop do it? alex_tdi VW MKIV-A4 TDIs (VE and PD) 2 August 26th, 2009 17:31
Replacing one strut? b1jackson Atlantic Canada 51 September 23rd, 2006 07:58
Page generated in 0.16995 seconds with 11 queries
[Output: 108.93 Kb. compressed to 91.91 Kb. by saving 17.03 Kb. (15.63%)]
