Old January 2nd, 2011, 12:34   #1
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
Default Cruise Control Drops, Traction Control Light Flashes
So, here is the problem. While driving on dry, even (a.k.a. no potholes) pavement with the cruise engaged, randomly the cruise will disengage just as the traction control indicator light shows briefly on the dash (obviously linked for safety reasons).
Starting doing this immediately after replacing the outer boot on the passenger side CV axle. At first, could not go more than a few miles between occurrences.
No codes in the computer (checked with my VAG-COM).
While driving, wheel speed sensors are all measuring the same values.
All CV axle bolts were tightened properly.
Pulled both front wheel speed sensors, cleaned and replaced.
After doing the above, it has done the same thing once in about 250 miles of driving. Any thoughts on what could be the issue?
  1. Bad wheel speed sensor? If so, how to test (note comment about VAG-COM above).
  2. Improper adjustment of wheel speed sensor? If so, what is the proper way to install them, just shove all the way in, or back off a touch after bottoming?
  3. Anything other thoughts?
Everything else is in good shape and tight.
Thanks,
Steve
Past as of 12/9/2016 - 2012 Jetta Sportwagen TDI - Platinum Gray, Black, DSG, Panoramic Roof
Past: 2005 Passat GLS TDI Wagon - Silverstone w/ Anthracite Leather - Unchained
Past: 2000 Jetta GLS TDI 5 Speed - Galactic Blue w/ Tan Leather
Alchemy is offline   Reply With Quote
Old January 2nd, 2011, 13:02   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
It's probably a dirty wheel speed sensor or sensor tonewheel.
-J
Present:
2018 Tesla Model 3 DM. 50,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 32,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old January 2nd, 2011, 13:09   #3
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
Cleaned both sensors (mentioned above) and cleaned the tonewheel/triggerwheel when the CV axle was out.
-J
Old January 2nd, 2011, 14:16   #4
s4phillips
s4phillips's Avatar
Location: Live in d/FW, TX. Transplanted from the Pacific Northwet
Steering sensor? http://forums.tdiclub.com/showthread.php?t=296715
Perform scheduled maintenance; drive more, worry less; balance shaft module; drive more, worry less; torque converter; drive more, worry less...
2005 Passat Wagon TDI w/gear driven buzz reducer and lubricant circulator
2002 Beetle TDI
2003 DL1000K3
s4phillips is offline   Reply With Quote
Old January 2nd, 2011, 14:21   #5
rarmstrong
Do you have VW axles on this car? If you have chinese junk axles I'll bet you its your problem...
Rob Armstrong
Charlotte, NC
2004 Passat GLS TDI PD 161k UPSOLUTE'D and UNCHAINED!!
2006 Honda Odyssey EXL 100k
2003 Honda S2000 42k Silverstone w Red interior
rarmstrong is offline   Reply With Quote
Old January 2nd, 2011, 17:11   #6
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
The original axles were removed from the car 20k miles ago, rebuilt and reinstalled. The boot split a few weeks ago on the passenger side, so I pulled it and put an OEM boot on it.
So, what specifically about Chineese axles would cause the problem, other than the country of origin?
Old January 2nd, 2011, 18:00   #7
rarmstrong
http://forums.tdiclub.com/showthread...vibration+axle
Have a look at the link and it will give you the background. If you are still on vw stuff its prob not the axle.
Rob Armstrong
Charlotte, NC
Old January 2nd, 2011, 18:08   #8
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
A bad brake light bulb or brake light switch will disengage the CC.
It's another place to look...
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old January 2nd, 2011, 19:36   #9
johnboy00
Bill
That will disengage the CC but it won't light the traction control light.
John
2005 Passat Wagon
2004 Jetta Auto
2003 IBW
1999.9 Golf (for parts)
johnboy00 is offline   Reply With Quote
Old January 2nd, 2011, 20:05   #10
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
Right, but I do not have a vibration issue. Just trying to understand what specifically the issues are between Chineese axles and the problem I am experiencing.
Old January 2nd, 2011, 20:07   #11
Alchemy
Alchemy's Avatar
Fuel Economy: N/A
Brake switch fine... If defective will not activate the TC circuit/light
Bill
Page generated in 0.15290 seconds with 10 queries
[Output: 105.31 Kb. compressed to 88.94 Kb. by saving 16.37 Kb. (15.55%)]
