Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > South Central Regional States
South Central Regional States Local discussions for those on the South Central US. (Arkansas, Louisiana, Oklahoma and Texas)
Old July 29th, 2010, 19:48   #46
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Originally Posted by DDLTexan View Post
Jetta 97,
I have a 1998 Jetta TDI in storage that my old mechanic could not fix. It lost power a couple of times driving from Texarkana to Dallas and put out some white smoke. I would slow down to about 20 mph and then the power would come back and I would then be able to drive about 60 mph. It did this several times over a distance of 100 miles with losing power and then power coming back. It finally stopped along side of the road and I had AAA tow it to my mechanic. We had the injector pump rebuilt and the timing belt replaced, etc. but it still won't run properly. It has been stored a couple of years, because I have been buried with a building project at home. I think the fuel tank needs to be totally flushed first (because the fuel in it is very very old) and then someone who can test it out properly with Vagcom, etc. Please PM and let me know what you might charge to finally get this car back working and on the road again.
Thanks for any help that you can provide, Alan
PM Sent.
USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic,
I do any repair on all models,
ECU TUNING/PROGRAMING-MK6 Needle Sweep,MK5 with MK6 Cluster
https://www.advancedcarelectronics.com/
jetta ,97 is offline   Reply With Quote
Old August 1st, 2010, 09:35   #47
TDIinTexas
TDIinTexas's Avatar
Originally Posted by jetta ,97 View Post
UPDATE:
Now I can do On Jetta ,Golf MK4 and Passat B5.5 function "windows open close with remote control".
Video:
http://www.youtube.com/watch?v=M4Wbrx1CdH8
Well Marin helped me out with this little trick yesterday. I didn't know if was possible on the MK4's without the module, boy was I wrong.
Thanks Marin!
David
02 Jetta Wagon TDI, GTB2265VKLR, Fun stuff to come...
TDIinTexas is offline   Reply With Quote
Old August 14th, 2010, 06:35   #48
WINMAG
TDI(s): 2004 JETTA
Fuel Economy: Good enough to make the wife happy
Default Recommendation for Marin
My experience:
Had a brake issue on the wife's jetta. Called Marin up and explained the issue to him and he gave me some usefull diagnostic instructions over the phone. Through my lack of understanding in the brake booster/master cylinder area on VW's, I thought it'd be better if someone took a look at it. Didn't want to mess around with an issue like braking so I scheduled an appointment to see Marin. Within minutes the problem was found but was unable to get the part till the next day. Met Marin at his residence and finished the job within minutes. As someone who deals with a vast range of people(everyday) in my career, Marin appears to be a knowledgeable, caring mechanic and a genuine nice guy. Everyone here knows trusting your car to someone is important and knowing their not trying to screw ya is peace of mind. As my Tdi is about to hit 200k miles I'm fully aware that its gonna need some tlc and would use Marin in a heartbeat for the job. Give him a try you won't be disappointed. Pm me if have any questions. Thanks everyone for this site.
WINMAG is offline   Reply With Quote
Old August 22nd, 2010, 21:13   #49
jrip
Fuel Economy: 44.5/41/39
A quick note of thanks Marin. The AC is working perfectly now and my wife is very happy. I appreciate you getting me in on short notice, and the first class repair. Of course the price was also great. The new maf has made a world of difference in the power and I have ordered that air pipe. It should be in before I leave for Colorado. Enjoy your vacation, and I'll see you when I get back for the suspension work.
Democracy, is two wolves and a lamb discussing whats for dinner. Freedom, is a well armed lamb contesting the vote.
2000 Jetta, 5-spd, Panzer Plate, 5 brake light mod, rear fog light mod, euro-switch, stupid door switch mod, 2007 Sebring antenna, Frost heater, coolant migration mod, EGR Delete, EGR Cooler delete, chip mod.
jrip is offline   Reply With Quote
Old September 10th, 2010, 06:07   #50
TDIFTW
my experience:
first of let me start off with, i cannot say enough positive things about marin, he does quality work at a resonable price and i will definatly recommend him to anyone with a VW. that being said here is my story
i started off researching the DMF because i kept hearing a noise at idle that was not normal. the information on this site helped me to realize that my DMF was more then likely failing. so i made a post asking about shops around the DFW metroplex. Marin's name came up in the second responce to my post (thanks schillster1) so i did some research and found this thread that marin had made and all the positive feedback people had been giving him.
i send marin a PM on a thursday, he gives me a call that night and we talk about the issues that i am having for about 30-45 min, and i schedule to take my car to him on monday (labor day). marin immediatly notice the problem of my DMF when i pulled up to his shop. he told me that it would be ready on thursday at the latest on friday. marin calls me on thursday to tell me that my car is ready and even makes arrangements for me to pick up at his house (since i work 7-6 m-f). when i show up to get my car he has the old flywheel there to show me the problem (how much play is in the flywheel). explains everything that he did to it and rides with me on a test drive to make sure that i am happy with it. we continue to shoot the breeze for another 30 min after that.
so like i said before.... marin is top notch!!!! ill definatly recommend anyone to him for work! the things that he did for me were : replace the DMF, 80k DSG service, and vag-com. in the future he will be doing my timing belt too. i am 100% satisfied in my expierience with marin. i am also glad to have such intelligent and strong VW supporters on this site that are willing to help others!! a big thank you to marin and to TDIclub for the info!!!!!
mitch
TDIFTW is offline   Reply With Quote
Old September 14th, 2010, 20:15   #51
lowhpdiesel
TDI(s): 02 tdi 5spd
can you send me a pm on the price to change a timing belt?
02 Jetta tdi...stock... 08 duramax 551hp/1140trq
lowhpdiesel is offline   Reply With Quote
Old September 18th, 2010, 09:43   #52
jrip
Marin. Thanks for a great job on the front suspension. The front end is once again handling like it should. I tried a few high speed curves and it feels more stable then it was before, and the new dogbone has greatly reduced the shake at start and shut down. Now all I need is the chip.
Old September 19th, 2010, 06:36   #53
TXRanger83
TXRanger83's Avatar
Just wanted to let everybody know Marin is a top class mechanic, and he only does high quality work. He installed an alarm siren on my MY10 jetta sedan which had never been done before in the US, and he did such a great job it looks like it was done at the VW factory.
2010 Salsa Red TDI Sedan
Current Mods
OEM is the only way
TXRanger83 is offline   Reply With Quote
Old October 5th, 2010, 07:56   #54
TXRanger83
TXRanger83's Avatar
Click HERE to see the quality work Marin can do.
Current Mods
OEM is the only way
Old October 25th, 2010, 09:23   #55
dogan
TDI(s): 2002 Jetta
Default Still another recommendation for Marin
Id like to add another note about Marin. He saved me $1200 from the dealer cost in fixing my fuel injector pump. The best thing for me however was not the money saved, but that I found such a quality mechanic in my area (Dallas). He was able to get to the car very quickly and was extremely thorough. He took the time to explain everything, and he gave me some great maintenance advice. I'd strongly recommend him to any TDI owner.
dogan is offline   Reply With Quote
Old November 6th, 2010, 18:17   #56
Blue Moon
Default Two Thumbs Up for Marin
We have a 2003 Jetta TDI GLS 5-speed that we recently purchased after a long search for this specific model. It has a factory new engine which is the main reason we picked it over a few others we considered. While it is in very good shape, our goal is to keep it a long time so a trustworthy wrench is an absolute requirement.
We have a friend that is a certified VW powertrain mechanic that replaced the engine in our Jetta however he has recently changed positions and now manages a corporate car and truck fleet so his availability to work as a shade tree mechanic is very limited. Based on the feedback on this forum we had already decided to give Marin a try when the time arose. While we had hoped that it would be awhile before we crossed paths with Marin, the MIL alerted us of a problem so we set up an appointment to deal with the issue plus discuss ongoing maintenance.
Marin diagnosed the issue right away and also found a small diesel leak that he also repaired. He also changed our engine and gear oil. Marin was very thorough as he gave the Jetta an in-depth look that made us feel even better about our purchase. If the need should arise, I would not hesitate to recommend Marin. Two thumbs up.
Blue Moon
Blue Moon is offline   Reply With Quote
Old November 12th, 2010, 09:41   #57
TDIFTW
marin just did my timing belt on my 06 MKV TDI yesterday. i and very happy with the work he did again. he did it in one day, he replaced my TB, rollers and tensioners, water pump (with metal impeller), cabin filter, air filter, fuel filter, and oil change. while he was working on my car he found a heater hose that was expanded at the connection and he called me and asked me if i wanted it changed right now with a price and i choose to go ahead and change it. (turned out to be cheaper then what he had origionally quoted over the phone). Another plus about marin is that he keeps all the parts that he replaced on my car and when i pick it up he shows me the parts and explains why he needed to change it. marin was also nice enought to allow me to drop off my car and pick it up at his house because i work M-F 7a to 6p. marin also hooked me up on some questions that i had and a few small thing that i wanted fixed.
again 100% happy with the work i had done through marin. he is very throuogh and passionate about what he does. i reccommend him to everyone that i can.
Old December 14th, 2010, 16:36   #58
foster1108
TDI(s): Jetta 1998
I will agree with the other post, Marin does a great job.
I had the timing belt replaced at another shop and the the car just did seem right. The other shop did not set timing correctly after the belt replacement plus few other issues that were not done correctly by them.
Marin fix the problems with the timing, a check engine light (blow glow plug fuse) also had the theremosta replaced , cold morning the Jetta was not coming up to temperature.
He did a great job a good pricing and got the car back quickly.
The first cold morning after the work he gave me a call to make sure the car starting fine and was coming up to the correct temp. first time I've had someone who worked on my car call me check that everything was working fine.
Thanks again, would recommend him to anyone.
foster1108 is offline   Reply With Quote
Old December 23rd, 2010, 19:57   #59
thebigtman
thebigtman's Avatar
Thumbs up Thank you Marin!
Thanks to all who posted on this thread. I was contemplating purchasing a wagon located in Dallas so I had Marin check it out for me. First, Marin uncovered a lot. I know my way around domestics pretty well but I'm glad I had Marin on my side for this one. I've owned two GLI's, one Golf and one TDI prior to this so I was familiar with VW's but I'm no expert. Furthermore, since I was about 5 hours away, I needed someone on the ground to do an inspection so I didn't blow a whole day of work to look at a potential wagon to buy. Marin was my eyes and ears for this purchase and I couldn't have had anyone better for the job. I knew exactly what I was getting into at the end of our 30 minute conversation. The day before the inspection he took a lot of time to explain exactly what he does in a pre-purchase inspection and I relayed my concerns about what I knew about the car already. I could tell that he knew his stuff when he explained what he does to inspect a TDI and after he actually completed the inspection, I was even more impressed. I had access to one previous pre buy inspection performed at Rusty Wallis VW but Marin blew this one out of the water with what he found.
After Marin got me up to speed on the car, he told me that the seller had just called and asked when he could get the car back. Unbeknown to me, the seller had another buyer setup to view the car immediately after the pre purchase inspection. We were both floored since he never mentioned this to either of us in the several conversations we had leading up to the pre buy inspection! I wasn't even going to be given a chance to buy the car. I was 5 hours away with cash in hand but the seller explained that he had a buyer here with cash in hand. What was I to do?! I offered to paypal a deposit, drive up the next day or whatever else he wanted to feel comfortable turning away these other buyers. Marin even offered to put cash in the buyers hand right there for me and told him that he should at least give me the chance to buy the car since he knew I was out of town. I was shocked. The seller still persisted in letting the new potential buyers have a chance but he at least agreed to pay for my pre purchase inspection.
So, what did Marin do next? Well, he armed these new buyers with the knowledge he just gave me and passed along my pre-purchase inspection repair list to the potential buyers so they knew exactly what they would be getting into. I think it must have scared them because in the end, those buyers passed and I finally had my chance to buy the wagon.
Although most of the items on the repair list I could have accomplished at my shop in San Antonio, I had full confidence in Marin's ability and I knew I wanted a few of those things done prior to driving it home. So, who else better to do it than Marin??!!! Marin gave me a detailed quote, provided pictures, called me several times and drove the wagon 80 miles to make sure it was up to snuff before I flew in to drive it home. When I got to his shop, we must have spent at least an hour talking about my vehicle, his business philosophy and future plans. I managed 46.1mpg (ALH, auto trans) on the way home down I35 without incident. The TDI ran flawlessly. And just to show you what kind of guy Marin really is, he called me that night to make sure all was well and to inquire about the car.
Overall, it was an A+++ experience. I highly recommend that you at least call and talk to him if you need to get your TDI serviced or if you need a pre buy inspection. Without a doubt, he is on your side. Not only did I find one heck of a mechanic but I also consider him a new friend. Thank you Marin!
Once again, a big thanks to this forum. Without these reviews, I would have never found someone as thorough as Marin.
Tim
thebigtman is offline   Reply With Quote
Old December 23rd, 2010, 20:03   #60
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Tim:
Thanks for sharing your experience. We in Houston don't have a Marin to rely on and typically find ourselves in the DFW/FW are at one of the three really good guys there.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Page generated in 0.16556 seconds with 10 queries
[Output: 134.45 Kb. compressed to 113.56 Kb. by saving 20.89 Kb. (15.54%)]
