Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > South Central Regional States
South Central Regional States Local discussions for those on the South Central US. (Arkansas, Louisiana, Oklahoma and Texas)
Old December 12th, 2018, 10:30   #196
tikal
Fuel Economy: 37 MPG (~ 45% city)
Originally Posted by drum4iam View Post
do you know anyone who works on tdi in south Dallas ? my number is 972-816-1944
drum4iam@aircanopy.net
You can also check here:
Trusted TDI Mechanics - By State
tikal is offline   Reply With Quote
Old March 7th, 2019, 19:46   #197
Moparjr89
I have a 2006 jetta brm with an immbolizer issue, car will start for one second then shut off and the immbolizer light is blinking, how much to help me get it fixed? I am willing to ship you the cluster and key if needed to fix the issue.
Moparjr89 is offline   Reply With Quote
Old August 6th, 2019, 22:01   #198
TDIintheSkys
Marin -
I'm emailing you this:
Saga of the 2014 JSW SEL TDI parking brake warning light and 5 minute LOUD warning chime (that resets every time I come to a complete stop, so no, I can't live with it) continues... Ok, after hours of analysis, ripping out the center console and front seat, VW of Palm Springs (great people and service, btw). Has ascertained that....
The problem is not the hand brake sensor, not the brake fluid sensor or the wiring... My instrument cluster must have a short or the board must be bad. Problem is, doesn't appear you can just disconnect the parking brake wire to the cluster because it's already getting the correct signal and still malfunctioning!
So, does anyone have a solution short of buying a new instrument cluster and re-coding it? (dealer did give a quote of $725 for parts & labor, but I don't want to spend that on a car w/143k miles on it, if I can avoid it). I'm stuck! Thanks...
TDIintheSkys is offline   Reply With Quote
Old August 11th, 2019, 08:25   #199
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Originally Posted by TDIintheSkys View Post
Marin -
Email reply back to you few days ago.
Thanks.
USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic,
I do any repair on all models,
ECU TUNING/PROGRAMING-MK6 Needle Sweep,MK5 with MK6 Cluster
https://www.advancedcarelectronics.com/
jetta ,97 is offline   Reply With Quote
Old January 23rd, 2020, 14:58   #200
mk4_noob
TDI(s): 2003 Jetta
Fuel Economy: Best was 54, average is 40s
Hi, Iím new here but wanted to thank the members of this forum and jetta ,97 (Marin) for helping me keep and fix my 2003 tdi Jetta. I knew my car needed some work on the suspension/bushings but I didnít know what exactly, so I reached out to Marin after I saw this thread, and asked if he was available to take a look and help me get a list of what I needed. We met up, and he gave me a very thorough list of what was ok still, and what wasnít which was great because some things I thought were bad (shocks) were still in fine shape. He said it could be done by Thursday night, and I got a call Wednesday afternoon saying he had already finished! New control arm bushings, strut mounts, sway bar bushings, lower ball joints, rear pads and rotors, both cooling fans , new transmission fluid, break fluid flush, and he even installed the shifter bushings I had gotten from DieselGeek . Needless to say, my car feels fantastic now. If you are in the Dallas area and need some work done, send jetta ,97 a message. It is very nice to know a mechanic who is knowledgeable, fast, and honest. Also the total bill was less than I expected which was great for helping me explain to my wife why I wanted to put a large chunk of money into a 17 year old car 😊
Thanks again Marin,
-Kyle
mk4_noob is offline   Reply With Quote
Old February 22nd, 2020, 12:56   #201
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
Sometime around the middle of April I'll be coming up I-35 from Laredo to Dallas, then east to Texarkana.
Looking to have my DSG fluid changed on my Passat and an idea of the cost.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.Scangauge II
Jetta_Pilot is offline   Reply With Quote
Old March 3rd, 2020, 07:14   #202
jetta ,97
jetta ,97's Avatar
PM Sent.
Old May 30th, 2020, 07:56   #203
jetta ,97
jetta ,97's Avatar
Just to let everyone know I open website now for all ECU/Cluster related problems and Chip Tuning stuff:
Best Regards
Old June 20th, 2020, 20:24   #204
r_boyd
Hello Marin ,
I lost your number I have a 2013 Mercedes sprinter motor and am getting 207d and 214d error codes. Can you help with and what’s the address of your shop.
Thanks,
Rayman Boyd
r_boyd is offline   Reply With Quote
© 1996 - 2020, All Rights Reserved
Page generated in 0.10328 seconds with 10 queries
[Output: 94.90 Kb. compressed to 81.63 Kb. by saving 13.27 Kb. (13.99%)]
